Highlighted
Beginner
Nexus 7K Ethanalyzer not available?
Hi All-
I am trying to do some troubleshooting - in the lab, in a non-prod environment.  I am looking to test Ethanalyzer, but it does not seem to be available on my switch.  Is there a feature that is necessary or some other prerequisite that I am missing?
7702-1.lab-CORE# ethanalyzer local interface inband display-filter ip.addr==1.2.3.4 limit-captured-frames 20
% Invalid command at '^' marker.
c7702-1.lab-CORE# sh ver Cisco Nexus Operating System (NX-OS) Software TAC support: http://www.cisco.com/tac Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html Copyright (c) 2002-2015, Cisco Systems, Inc. All rights reserved. The copyrights to certain works contained in this software are owned by other third parties and used and distributed under license. Certain components of this software are licensed under the GNU General Public License (GPL) version 2.0 or the GNU Lesser General Public License (LGPL) Version 2.1. A copy of each such license is available at http://www.opensource.org/licenses/gpl-2.0.php and http://www.opensource.org/licenses/lgpl-2.1.php Software BIOS: version 3.1.0 kickstart: version 7.2(0)D1(1) system: version 7.2(0)D1(1) BIOS compile time: 02/27/2013 kickstart image file is: bootflash:///n7700-s2-kickstart.7.2.0.D1.1.bin kickstart compile time: 5/19/2015 11:00:00 [06/14/2015 16:46:24] system image file is: bootflash:///n7700-s2-dk9.7.2.0.D1.1.bin system compile time: 5/19/2015 11:00:00 [06/14/2015 18:40:21] Hardware cisco Nexus7700 C7702 (2 Slot) Chassis ("Supervisor Module-2") Intel(R) Xeon(R) CPU with 32744992 kB of memory. Processor Board ID xxx Device name: c7702-1.lab-CORE bootflash: 4014080 kB slot0: 0 kB (expansion flash) Kernel uptime is 318 day(s), 3 hour(s), 32 minute(s), 1 second(s) Last reset Reason: Unknown System version: 7.2(0)D1(1) Service: plugin Core Plugin, Ethernet Plugin
1 ACCEPTED SOLUTION
Highlighted
Hi Wes,
On early versions of N7K NX-OS software, Ethanalyzer can only be executed from the admin/default VDC. Are you attempting to run Ethanalyzer on the admin VDC, or on a "child" VDC?
Later N7K NX-OS software (I believe 8.x, but I don't recall the exact NX-OS software release) allows Ethanalyzer to be executed from a child VDC as well as the admin VDC.
Be forewarned that in earlier NX-OS software releases, because Ethanalyzer is executed on the admin VDC, the control plane traffic received on all child VDCs will be visible in Ethanalyzer. As such, you may need to use a combination of display-filters and capture-filters to troubleshoot the specific flow or type of traffic that you want.
I hope this helps - thank you!
-Christopher
2 REPLIES 2
Highlighted
Hi Wes,
-Christopher
Highlighted
Ahh - thanks for the explanation!
Content for Community-Ad
