1126
JaneLeisure1133
Beginner
Nexus 7K VDC deletion impact
I have a Nexus 7004 with an unused VDC.  Will deleting it have any impact on the other VDCs?  Thanks.
1 ACCEPTED SOLUTION
Christopher Hart
Hi Jane,
If the VDC is truly unused (meaning, it does not have any interfaces allocated to it), then deleting the VDC should not cause any impact to other existing VDCs in use. With that being said, I would recommend performing the change during a maintenance window if possible just in case.
Thank you!
-Christopher
2 REPLIES 2
Christopher Hart
Hi Jane,
Thank you!
-Christopher
Great, thank you!
