Nexus 9336c-FX2 LACP load balancing Hash Algorithm
Peyman Zadmehr
In the following link, it was not mentioned that we can change LACP load-balancing Algorithm on 9300-FX2 but it was directly motioned that we can do this on 9200,9300-EX and 9300-GX :
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/interfaces/configuration/guide/b-cisco-nexus-9000-nx-os-interfaces-configuration-guide-93x/b-cisco-nexus-9000-nx-os-interfaces-configuration-guide-93x_chapter_010000.html#conc...
This is applicable for NXOS9.3
While in Version 7.x This was not mentioned:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x_chapter_0111...
I want to ask, Is changing the hash algorithm of LACP supported on 9336x-FX2 or not? and which document is correct?
Is this mean by upgrading NXOS from 7.x to 9.3 we will lose an ability?
Thank you
Peyman Zadmehr
Can you please help me out?
Thank you
Sergiu.Daniluk
Hi @Peyman Zadmehr
Based on the documentation 9300-FX2 does support different load balancing algorithms:
  • Port-channel symmetric hashing is supported on Cisco Nexus 9200, 9300-EX, 9300-FX/FX2, and 9300-GX platform switches and Cisco Nexus 9500 platform switches with N9K-X9732C-EX, N9K-X9736C-EX, N9K-X9736C-FX, and N9K-X9732C-FX line cards.
Reference Guidelines and limitations: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/93x/interfaces/configuration/guide/b-cisco-nexus-9000-nx-os-interfaces-configuration-guide-93x/b-cisco-nexus-9000-nx-os-interfaces-configuration-guide-93x_chapter_010000.html#id_1...
As a rule of thumb, when it comes to load balancing on Nexus platforms, check whatever the port-channel load-balance command lists as options and that is what is supported. If is not supported, I would expect a syslog message saying is not supported (hopefully).
If you already have a specific hashing configured and working in 7.x, the expected behavior, unless specified otherwise, is that it will work on 9.x as well. If you see any deviations, definitely open a case with DCRS TAC team.
Cheers,
Sergiu
Dear Sergiu
Thank you for the answer.
My concern is this phrase in the mentioned document:
Configuring hash load balancing applies to unicast and multicast traffic on Cisco Nexus 9200, 9300-EX, and 9300-GX Series switches.
Does this means It is not supported on FX2 models? Personally I think it should be since FX2 models are more powerful..
About Symmetric Hashing, I think it is applicable for IP traffic, What should I do for Layer-2 traffic?
Can I change the Hash algorithm for Src-Dst MAC?
Thank you
Peyman
