Nexus 9348GC-FXP - Possbility to create vPC domain including SVIs
qvest_gwb
Dears,
I am wondering, if it would be possible to create a vPC domain including VLAN SVIs, utilizing for instance HSRP for HA, on a pair of Cisco Nexus 9348GC-FXP. From the NX-OS documentation, it seems that there is no difference in software and licensing between this model or let's say another Nexus 9300-FX series model such as the Nexus 93160YC-FX, which I know supports these features. Any ideas?
Many thanks,
Georg
Alex.M
Hi qvest_gwb,
The 9348GC-FXP is apart of the Nexus 9000 FX series switches.  It will support the layer 3 features like SVI's, HSRP, etc as well as the layer 2 features (vPC) mentioned.  Here is a link to features found on the FX series switches like the 9348GC-FXP.  A general rule of thumb to the Nexus 9000's is they typically support the same features (apart from FC) but differ in hardware resources.
HTH,
Alex
