02-11-2022 05:17 AM
I have 4 new 9504 switch being prepared to replace catalyst 6509's. They have been sitting in the DC's for several months powered up config in place waiting for the migration.
A check to day show 2 of the 4 switches reporting the following;
Mod Ports Module-Type Model Status
1 52 48x10G + 4x40/100G Ethernet Module N9K-X9788TC-FX powered-dn
2 52 48x10/25G + 4x40/100G Ethernet Module N9K-X97160YC-EX powered-dn
3 52 48x10/25G + 4x40/100G Ethernet Module N9K-X97160YC-EX powered-dn
From the log
2022 Feb 10 11:55:19 cen-msl-sw-01-new %PLATFORM-2-MOD_DETECT: Module 3 detected (Serial number FOC244301UH) Module-Type 48x10/25G + 4x40/100G Ethernet Module Model N9K-X97160YC-EX
2022 Feb 10 11:55:19 cen-msl-sw-01-new %PLATFORM-2-MOD_PWRUP: Module 3 powered up (Serial number FOC244301UH)
2022 Feb 10 11:55:19 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 3 current-status is MOD_STATUS_POWERED_UP
2022 Feb 10 11:55:21 cen-msl-sw-01-new %PLATFORM-2-MOD_DETECT: Module 2 detected (Serial number FOC244301X1) Module-Type 48x10/25G + 4x40/100G Ethernet Module Model N9K-X97160YC-EX
2022 Feb 10 11:55:21 cen-msl-sw-01-new %PLATFORM-2-MOD_PWRUP: Module 2 powered up (Serial number FOC244301X1)
2022 Feb 10 11:55:21 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_POWERED_UP
2022 Feb 10 11:55:21 cen-msl-sw-01-new %PLATFORM-2-MOD_DETECT: Module 1 detected (Serial number FOC244133PM) Module-Type 48x10G + 4x40/100G Ethernet Module Model N9K-X9788TC-FX
2022 Feb 10 11:55:21 cen-msl-sw-01-new %PLATFORM-2-MOD_PWRUP: Module 1 powered up (Serial number FOC244133PM)
2022 Feb 10 11:55:21 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_POWERED_UP
2022 Feb 10 11:55:33 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 3 IOFPGA booted from Primary
2022 Feb 10 11:55:33 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 3 MIFPGA booted from Primary
2022 Feb 10 11:55:33 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 3 BIOS booted from Primary
2022 Feb 10 11:55:35 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 2 IOFPGA booted from Primary
2022 Feb 10 11:55:35 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 2 MIFPGA booted from Primary
2022 Feb 10 11:55:35 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 2 BIOS booted from Primary
2022 Feb 10 11:55:36 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 1 IOFPGA booted from Primary
2022 Feb 10 11:55:36 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 1 MIFPGA booted from Primary
2022 Feb 10 11:55:36 cen-msl-sw-01-new %CARDCLIENT-5-MOD_BOOT_PRIMARY: Module 1 BIOS booted from Primary
2022 Feb 10 11:57:47 cen-msl-sw-01-new %PLATFORM-2-MOD_PWRDN: Module 3 powered down (Serial number FOC244301UH)
2022 Feb 10 11:57:47 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 3 current-status is MOD_STATUS_CONFIGPOWERED_DOWN
2022 Feb 10 11:57:47 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 3 current-status is MOD_STATUS_POWERED_DOWN
2022 Feb 10 11:57:48 cen-msl-sw-01-new %PLATFORM-2-MOD_PWRDN: Module 2 powered down (Serial number FOC244301X1)
2022 Feb 10 11:57:48 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_CONFIGPOWERED_DOWN
2022 Feb 10 11:57:48 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 2 current-status is MOD_STATUS_POWERED_DOWN
2022 Feb 10 11:57:51 cen-msl-sw-01-new %PLATFORM-2-MOD_PWRDN: Module 1 powered down (Serial number FOC244133PM)
2022 Feb 10 11:57:51 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_CONFIGPOWERED_DOWN
2022 Feb 10 11:57:51 cen-msl-sw-01-new %PLATFORM-5-MOD_STATUS: Module 1 current-status is MOD_STATUS_POWERED_DOWN
Mod Power-Status Reason
1 powered-dn Reset (powered-down) because module does not boot
2 powered-dn Reset (powered-down) because module does not boot
3 powered-dn Reset (powered-down) because module does not boot
All other cards in the switch are working fine.
Has anyone seen this issue.
Soft resets have tried don't work
Power Cycle doesn't work.
Solved! Go to Solution.
02-11-2022 07:56 AM
Hi Russell,
I appreciate you providing that output! The "Module initialization failed (DevErr is received syserr or failing sap)" error code reported in the output of show module internal exceptionlog can indicate many different issues, all of which require some more in-depth analysis.
To move forward with this, I would recommend opening a support case with Cisco TAC so that Cisco can investigate this further and provide you with a conclusive root cause. I highly recommend proactively attaching the output of the show tech-support details from both switches encountering this issue, as that will help TAC investigate further.
Thank you!
-Christopher
02-11-2022 06:07 AM - edited 02-11-2022 06:08 AM
Hi Russell,
This looks like somebody manually powered down these line cards through the poweroff configuration command. You can confirm this with the show running-config | include poweroff command, which should show that all three modules are manually powered off.
To correct this, you can use the configuration commands below to bring the line cards back online:
switch# configure terminal
switch(config)# no poweroff module 1
switch(config)# no poweroff module 2
switch(config)# no poweroff module 3
switch(config)# end
switch# copy running-config startup-config
[########################################] 100%
Copy complete, now saving to disk (please wait)...
Copy complete.
switch#
I hope this helps - thank you!
-Christopher
02-11-2022 07:09 AM
02-11-2022 07:34 AM
Hi Russell,
Apologies, you're correct - I checked in my lab, and when a line card is manually powered down, a reason of "Configured Power down" is shown in the output of show module. Obviously, your switch is showing a different reason.
A few questions:
Thank you!
-Christopher
02-11-2022 07:39 AM
02-11-2022 07:56 AM
Hi Russell,
Thank you!
-Christopher
