764
fawad-alam
Explorer
Nexus 'Buffer Boost' command
I am working on Nexus 9500 series 40G line card 9432PQ. This card requires the port-channel be configured with 'no buffer boost' command - although the port capabilities shows that ports on this LC do not have 'buffer boost' feature enabled.
The problem I am observing is that as soon as port-channel is configured with 'no buffer boost' it causes issue with some applications. the packets start dropping and as a result the application suffers.
Anyone experienced this problem, anything could be applied as a fix?
3 REPLIES 3
Glenn854
Beginner
This card requires the port-channel be configured with 'no buffer boost' command  although the port capabilities shows that ports on this LC do not have 'buffer boost' feature enabled.
RapidFS
gibiso9807
Beginner
So the main problem is to buffer boost but with the problem it will take time to enter the proper command.It will work fine with some applications.The dissertation help can provide you with proper assistance in order to prepare for your final exams.
These essay writing services can be found online by reading edusurf reviews, which will assist you in selecting the top essay writing services and avoiding being a victim of scam. This may be avoided by keeping track of how properly the website is designed and maintained, as well as the credentials and experience of the team members.
