I'm currently struggling to understand what certificate options are supported on the N1KV. I'm looking to use the switch in an environment where self-signed certificates are not acceptable, and therefore wish to enroll with an internal CA to further protect communications between the VSM and vCentre. The issue is that the 1000v doesn't seem to support any of the command line options required for this on a normal IOS/NX-OS box.
Any ideas or pointers?
Doug
