Highlighted
Beginner
NXOS mode : Is it Possible to Use the Nexus 9300 as the parent switch for Fex 2K Fex in the following Topology?
NXOS mode
Is it Possible to Use the Nexus 9300 as the parent switch of N2K fex, in the following Topology? (NXOS)
N5696Q is going to be EOS/EOL @ May 2021, and for keeping the DataCenter topology as it was , so it can be expanded with Nexus 9300 instead of Nexus5696Q (EOS in May 2021)
  1. Is there any problems with this solution?
  2. Does this Solution work Properly, same as it was working with N5k before.
Same as what Nexus 5K was the parent switch in the common classical Datacneter topologies (NXOS)111.jpg
Architecture is :
Server to Fex = etherchannel , vPC
Fex to N5696Q = straight through connection (Etherchannel)
N5696Q to N7K = vPC
L2/L3 Boundry = N7K
Are there any important considerations that need to be taken?
For example, i found the 3 following considerations:(are there more?)
- Mostly Straight-Through connection between Fex and N9300 is required(No problem)
- Nexus 9300 only supports 16 x Fex (should be considered)
- FET cable is not supported between N2348UPQ and N9300 (should be considered)
3 REPLIES 3
Highlighted
VIP Engager
Hi @S. B
The N9K switches needs to be configured in a vPC domain - vpc peer-link is missing on the topology, so this is why I am mentioning (however for double-sided vpc between 9k and 7k you do need vpc, so i guess the existence of the vpc domain is implied)
Make sure you run a NXOS version which supports the FEXs. For example 9.3.1 for N9K-C93360YC-FX2 and 9.2.1 for the other two model. Reference: https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/fexmatrix/fexmatrix.html
- Mostly Straight-Through connection between Fex and N9300 is required(No problem) -> Only single homed FEXs are supported for your N9K switches.
Stay safe,
Sergiu
Highlighted
Dear @msdaniluk
I edited the images.
I had forgotten to add the vpc links.
This is the correct diagram.
Does this solution work now?
Highlighted
Yes is supported.
Have a look over the supported topologies:
https://www.cisco.com/c/en/us/support/docs/switches/nexus-2000-series-fabric-extenders/200363-nexus-2000-fabric-extenders-supported-un.html
Topology: Host VPC (Dual Links) and FEX Single Homed (Port Channel Mode) Straight through VPC Design
Stay safe,
Sergiu
Content for Community-Ad
