Observed "FAIL. Return code 0x4093007C (Issu cannot be done, bootflash is busy)." while upgrading cisco 5548up switches from 7.1(4)N1(1) to 7.3(7)N1(1).
binodsatapathy7
Issue :
Details log while upgrading switch:
R1-CS-5548-A-U42# install all kickstart bootflash:///n5000-uk9-kickstart.7.3.7.N1.1.bin system bootflash:///n5000-uk9.7.3.7.N1.1.bin
Verifying image bootflash:/n5000-uk9-kickstart.7.3.7.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.7.3.7.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.7.3.7.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n5000-uk9-kickstart.7.3.7.N1.1.bin.
Extracting "bios" version from image bootflash:/n5000-uk9.7.3.7.N1.1.bin.
Performing module support checks.
Notifying services about system upgrade.
[####################] 100% -- FAIL. Return code 0x4093007C (Issu cannot be done, bootflash is busy).
Service "stp" in vdc 1: Port: Ethernet1/15 in VLAN0053 is Designated. Topology change could occur during ISSU.
Upgrade needs to be disruptive!!!
(modified the impact to <Hitful> for module <1>)
Install has failed. Issu cannot be done, bootflash is busy (0x4093007C)
Error Id: 0x4093007C
Error Facility: installer
Error Description: Issu cannot be done, bootflash is busy
Checking the process(s) using the bootflash...
dcos_sshd /bootflash
Bootflash is busy due to :
[1] Open or active SFTP session. Close the sftp session and try the "install all" command again.
R1-CS-5548-A-U42#
Can someone help me with upgrading this switch?
Note :
I have 2 cisco 5548up switches in a fabric. I am facing this issue only one switch. Another switch not throwing this error.
Currently, both the switches are the same firmware version(7.1(4)N1(1)).
2 Accepted Solutions
Sergiu.Daniluk
Hi @binodsatapathy7
You have two problems mentioned there:
For ISSU to Proceed, Check the Following Criteria :
1. No Topology change must be active in any STP instance
2. Bridge assurance(BA) should not be active on any port (except MCT)
3. There should not be any Non Edge Designated Forwarding port (except MCT)
4. ISSU criteria must be met on the VPC Peer Switch as well
If Ethernet1/15 is connected to a server/endpoint/device not running STP, configure it as an edge port:
conf t
interface eth x/y
spanning-tree port type edge
If your N5K is not a leaf in your STP topology and you cannot configure the port as edge, then your upgrade will be disruptive (non-ISSU).
Do you have any SFTP connection opened? If yes, close it and try again the install all cmd.
If you want to force a cold upgrade (non-ISSU), you can do it through:
install all force kickstart <kickstart_image.bin> system <system_image.bin>
Cheers,
Sergiu
how did you resolve it?
Sergiu.Daniluk
Hi @binodsatapathy7
conf t
interface eth x/y
Cheers,
Sergiu
Thanks for your help.
I am able to upgrade the switch successfully.
Binod
