01-07-2019 01:36 AM
I would like to have more information about NetFlow and OpenFlow application on Nexus 31108PC-V platform.
In my scenario I have a Nexus 31108PC-V with release 7.0(3)I4(3) and base license, I can see the feature NetFlow in "show feature" output:
SW-N3K-2# show feature
Feature Name Instance State
netflow 1 disabled
but I can't enable it bicause in configuration mode this feature is not available:
SW-N3K-2(config)# feature n?
ntp Enable/Disable NTP
nv Enable/Disable VxLAN
nxapi Enable/Disable nxapi
Instead, OpenFlow seems a feature not available.
Could be a license restriction?If yes, which license is needed? What else?
Thanks in advance.
Best regard
Gian Luca
Solved! Go to Solution.
01-14-2019 11:42 PM
Hi Peter,
I know that NetFlow and OpenFlow are two different feature and there aren't relation between the two.
If is better I open a discussion dedicated to OpenFlow.
Gian Luca
01-07-2019 12:51 PM
Hello Gian Luca,
Unfortunately, the 31108PCV switch does not support NetFlow. The fact you saw the NetFlow feature printed out in the show feature is in fact a cosmetic defect only; that feature should not have been listed there at all. The 7.0(3)I7(5) does not report this feature anymore:
N3K2(config)# show ver | i NXOS|Chassis NXOS: version 7.0(3)I7(5) NXOS image file is: bootflash:///nxos.7.0.3.I7.5.bin NXOS compile time: 8/28/2018 2:00:00 [08/28/2018 09:51:46] cisco Nexus 31108PCV Chassis (Nexus 9000 Series) N3K2(config)# show feature | i flow openflow 1 disabled sflow 1 enabled N3K2(config)# feature n? nat Enable/Disable NAT netconf Enable/Disable netconf Services ngoam Enable/Disable ngoam ntp Enable/Disable NTP nv Enable/Disable VxLAN nxapi Enable/Disable nxapi nxsdk Enable/Disable nxsdk Services
I am sorry to disappoint you; you will not be able to start NetFlow on this platform (in fact, no N3K platform currently supports it).
OpenFlow is an entirely different and unrelated mechanism; it is not used for traffic statistics collection but rather to control traffic forwarding entries in the hardware. We should not talk about OpenFlow in relation to NetFlow at all; these two are entirely different things.
Best regards,
Peter
01-14-2019 11:42 PM
Hi Peter,
Gian Luca
01-15-2019 09:30 AM
Hello Gian Luca,
My apologies - since you have been talking about the two unrelated features in the same thread, and did not really clarify what exactly are you focusing on with the OpenFlow, I was not sure if you were confusing the two. I apologize - I meant no offense.
Maybe it would be better to open another thread just for the OpenFlow issue you are looking at.
Thank you!
Best regards,
Peter
