07-02-2019 08:12 AM
Hello
Can you tell me what these sentences mean?
"Provides single-touch site configuration"
"Preserves existing Layer 3 failure boundaries"
"Provides automated multihoming"
These are discussed in the following link
Thankyou
07-03-2019 08:23 PM - edited 07-03-2019 08:23 PM
"Provides single-touch site configuration for adding new data centers"
To interconnect a new Data Center to others already interconnected using OTV, you do not have to go to every existing site and add any command in its existing configuration.
Only on the new site you will configure the OTV overlay and related commands.
The OTV provides STP isolation, unknown unicast traffic suppression, and ARP optimization, to stop this traffic from traversing the DCI link (Data Center Interconnect).
If you have more than one OTV edge device at a site, they will automatically multi-home.
OTV edge devices at the same site exchange hello packets that are based on the fact that they are configured with the same site VLAN and they have the same site-identifier.
OTV will elect an AED on per-VLAN basis. The OTV edge device for a given VLAN will then proceed to advertise MAC addresses and forward traffic. If one of the edge devices fails or loses overlay connectivity, the other will take over forwarding for VLANs of the failed device.
I hope this helps.
Regards.
