Hello community
I'm trying to configure OTV on my lab with Cisco Csr1000v version (17.3.4a), I have 4 routers ( 2 on each site), when I do "show otv detail", I get this output:
CSR-1#show otv detail
Overlay Interface Overlay1
VPN name : None
VPN ID : 1
State : UP
Fwd-capable : No
Fwd-ready : No
AED-Server : No
Backup AED-Server : No
AED Capable : No, overlay DIS not elected
IPv4 control group : 239.1.1.1
Mcast data group range(s): 239.100.100.0/24
Join interface(s) : GigabitEthernet1
Join IPv4 address : 10.1.1.11
Tunnel interface(s) : Tunnel0
Encapsulation format : GRE/IPv4
Site Bridge-Domain : 1111
Capability : Multicast-reachable
Is Adjacency Server : No
Adj Server Configured : No
Prim/Sec Adj Svr(s) : None
OTV instance(s) : 0
FHRP Filtering Enabled : Yes
ARP Suppression Enabled : Yes
ARP Cache Timeout : 600 seconds
It seems like there's a problem in connectivity between the 2 boxes in the same site over the site vlan
When I try "show spanning tree vlan 1111" I get this output:
CSR-1#show spanning-tree vlan 1111
VLAN1111
Spanning tree enabled protocol ieee
Root ID Priority 33879
Address 001e.7a8a.a9bb
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 33879 (priority 32768 sys-id-ext 1111)
Aging Time 0 sec
Interface Role Sts Cost Prio.Nbr Type
CSR-1#
and for this is the configuration of csr interface on the LAN side:
CSR-1#show running-config interface gigabitEthernet 2
Building configuration...
Current configuration : 346 bytes
interface GigabitEthernet2
no ip address
negotiation auto
cdp enable
no mop enabled
no mop sysid
service instance 10 ethernet
encapsulation dot1q 10
bridge-domain 10
service instance 20 ethernet
encapsulation dot1q 20
bridge-domain 20
service instance 1111 ethernet
encapsulation dot1q 1111
bridge-domain 1111
end
CSR-1#
