05-08-2020 12:47 PM
I have a topology(attached) using 2x Cisco nexus 9396px switches in vpc mode. I enabled vxlan feature and I implement anycast vtep.
The anycast IP is 192.168.93.93. The switchA has the 192.168.93.101 and the SwitchB the IP 192.168.93.102.
Also, I have a different loopbacks for bgp evpn peering.
Between the 2 switch I have a L3 dedicated link (e1/5) which running OSPF for underlay loopback reachability.
I have advertise-pip and advertise virtual-rmac enabled.
The problem is that client1 cannot ping looopback on R1 router. The switch1 and switch2 have a route in vrf table for this loopback IP. I tried to capture the traffic and I can see that the packet reaches to switch2 but it not forwarding to the R1 via interface e1/3.
I also tried to create a seperate loopback in each switch in vrf (switchA: 10.10.10.93, switchB: 10.10.10.193). I announced these IPs in BGP and i tried to ping between these IPs. Unfortunatelly the ping is failing again. In the packet capture I can see the packets reaching the other switch with VXLAN encapsulation, but the reply is never generated.
Now the switches running the version 7.0(3)I7(7). I tried to upgrade to 7.0(3)I7(8) but with the same results.
Can you provide any insights on this?
05-09-2020 11:05 AM
Can you share the configuration? Your explanation is a little hard to follow.
Thanks!
05-09-2020 11:42 AM
05-09-2020 04:03 PM - edited 05-09-2020 04:25 PM
What is the client IP and which loopback is it trying to ping?
I assume the default gateway on the client is pointed to the anycast gw? this should work no problem as long as the loopback int is in the same vrf as the anycast gw int (on the same switch, i.e. if the client is connected to switch 2 and pings the loopback on switch 2, this works 100% as it's not even related to vxlan)
Pinging the loopback on switch1 from a client on switch 2 is where you need to redistribute it into bgp
It looks like you already did this in your config. so you need to verify on both switches:
show bgp ipv4 unicast vrf Customers
show bgp l2vpn evpn vrf Customers
show bgp l2vpn evpn route-type 5
See if the route is there (the loopback)
Only odd things I see is you have mac addresses set on the uplink interface.
You don't have peer-gateway, peer-switch enabled on VPC which is best practice.
Ahh i read it for the 5th time and thought you were referring to pinging the loopbacks on sw1/2 , but you want to ping the one on r1 which you didn't include the config for. I'd like to see the routing tables.
Can you ping r1 loopback from a client on switch 2? that wouldn't even use vxlan or evpn as it's in the same vrf locally connected. Once you verify that works we can move on to switch 1.
05-09-2020 04:49 PM
The client1 has the IP: 192.168.70.10 and client2 the IP: 192.168.70.20. They are using the anycast gateway 192.168.70.1.
The loopback behind R1 is the 10.88.88.88. I don't get any response when ping from the client1 to this loopback.
From client1 I can ping the loopback in SW1 (10.10.10.93) but not the loopback in SW2 (10.10.10.193). I can capture the VXLAN packet coming to SW2 but the SW2 never sends a response back.
On SW1:
Network Next Hop Metric LocPrf Weight Path *>l10.10.10.93/32 0.0.0.0 100 32768 i *>i10.10.10.193/32 192.168.93.102 100 0 i *>i10.88.88.0/24 192.168.93.102 0 100 0 65502 i * i192.168.70.0/26 192.168.93.102 100 0 i *>l 0.0.0.0 100 32768 i
Network Next Hop Metric LocPrf Weight Path Route Distinguisher: 10.0.93.101:33047 (L2VNI 28000) *>l[2]:[0]:[0]:[48]:[0050.7966.6803]:[0]:[0.0.0.0]/216 192.168.93.93 100 32768 i *>l[2]:[0]:[0]:[48]:[0050.7966.6803]:[32]:[192.168.70.10]/272 192.168.93.93 100 32768 i *>l[3]:[0]:[32]:[192.168.93.93]/88 192.168.93.93 100 32768 i Route Distinguisher: 10.0.93.102:3 *>i[5]:[0]:[0]:[24]:[10.88.88.0]:[0.0.0.0]/224 192.168.93.102 0 100 0 65502 i *>i[5]:[0]:[0]:[26]:[192.168.70.0]:[0.0.0.0]/224 192.168.93.102 100 0 i *>i[5]:[0]:[0]:[32]:[10.10.10.193]:[0.0.0.0]/224 192.168.93.102 100 0 i Route Distinguisher: 10.0.93.101:3 (L3VNI 900001) *>l[2]:[0]:[0]:[48]:[5000.0001.0007]:[0]:[0.0.0.0]/216 192.168.93.93 100 32768 i *>i[5]:[0]:[0]:[24]:[10.88.88.0]:[0.0.0.0]/224 192.168.93.102 0 100 0 65502 i * i[5]:[0]:[0]:[26]:[192.168.70.0]:[0.0.0.0]/224 192.168.93.102 100 0 i *>l 192.168.93.101 100 32768 i *>l[5]:[0]:[0]:[32]:[10.10.10.93]:[0.0.0.0]/224 192.168.93.101 100 32768 i *>i[5]:[0]:[0]:[32]:[10.10.10.193]:[0.0.0.0]/224 192.168.93.102 100 0 i
BGP routing table information for VRF default, address family L2VPN EVPN Route Distinguisher: 10.0.93.102:3 BGP routing table entry for [5]:[0]:[0]:[24]:[10.88.88.0]:[0.0.0.0]/224, version 2310 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Advertised path-id 1 Path type: internal, path is valid, is best path Imported to 2 destination(s) AS-Path: 65502 , path sourced external to AS 192.168.93.102 (metric 2) from 10.0.93.102 (10.0.93.102) Origin IGP, MED 0, localpref 100, weight 0 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0002.0007 Path-id 1 not advertised to any peer BGP routing table entry for [5]:[0]:[0]:[26]:[192.168.70.0]:[0.0.0.0]/224, version 2295 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Advertised path-id 1 Path type: internal, path is valid, is best path Imported to 2 destination(s) AS-Path: NONE, path sourced internal to AS 192.168.93.102 (metric 2) from 10.0.93.102 (10.0.93.102) Origin IGP, MED not set, localpref 100, weight 0 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0002.0007 Path-id 1 not advertised to any peer BGP routing table entry for [5]:[0]:[0]:[32]:[10.10.10.193]:[0.0.0.0]/224, version 61 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Advertised path-id 1 Path type: internal, path is valid, is best path Imported to 2 destination(s) AS-Path: NONE, path sourced internal to AS 192.168.93.102 (metric 2) from 10.0.93.102 (10.0.93.102) Origin IGP, MED not set, localpref 100, weight 0 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0002.0007 Path-id 1 not advertised to any peer Route Distinguisher: 10.0.93.101:3 (L3VNI 900001) BGP routing table entry for [5]:[0]:[0]:[24]:[10.88.88.0]:[0.0.0.0]/224, version 2311 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Advertised path-id 1 Path type: internal, path is valid, is best path Imported from 10.0.93.102:3:[5]:[0]:[0]:[24]:[10.88.88.0]:[0.0.0.0]/224 AS-Path: 65502 , path sourced external to AS 192.168.93.102 (metric 2) from 10.0.93.102 (10.0.93.102) Origin IGP, MED 0, localpref 100, weight 0 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0002.0007 Path-id 1 not advertised to any peer BGP routing table entry for [5]:[0]:[0]:[26]:[192.168.70.0]:[0.0.0.0]/224, version 2296 Paths: (2 available, best #2) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn Path type: internal, path is valid, not best reason: Weight Imported from 10.0.93.102:3:[5]:[0]:[0]:[26]:[192.168.70.0]:[0.0.0.0]/224 AS-Path: NONE, path sourced internal to AS 192.168.93.102 (metric 2) from 10.0.93.102 (10.0.93.102) Origin IGP, MED not set, localpref 100, weight 0 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0002.0007 Advertised path-id 1 Path type: local, path is valid, is best path AS-Path: NONE, path locally originated 192.168.93.101 (metric 0) from 0.0.0.0 (10.0.93.101) Origin IGP, MED not set, localpref 100, weight 32768 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0001.0007 Path-id 1 advertised to peers: 10.0.93.102 BGP routing table entry for [5]:[0]:[0]:[32]:[10.10.10.93]:[0.0.0.0]/224, version 15 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn Advertised path-id 1 Path type: local, path is valid, is best path AS-Path: NONE, path locally originated 192.168.93.101 (metric 0) from 0.0.0.0 (10.0.93.101) Origin IGP, MED not set, localpref 100, weight 32768 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0001.0007 Path-id 1 advertised to peers: 10.0.93.102 BGP routing table entry for [5]:[0]:[0]:[32]:[10.10.10.193]:[0.0.0.0]/224, version 65 Paths: (1 available, best #1) Flags: (0x000002) (high32 00000000) on xmit-list, is not in l2rib/evpn, is not in HW Advertised path-id 1 Path type: internal, path is valid, is best path Imported from 10.0.93.102:3:[5]:[0]:[0]:[32]:[10.10.10.193]:[0.0.0.0]/224 AS-Path: NONE, path sourced internal to AS 192.168.93.102 (metric 2) from 10.0.93.102 (10.0.93.102) Origin IGP, MED not set, localpref 100, weight 0 Received label 900001 Extcommunity: RT:65500:900001 ENCAP:8 Router MAC:5000.0002.0007 Path-id 1 not advertised to any peer
05-09-2020 05:12 PM
Hmm it's not being put where it should be.
show l2route mac-ip all
show forwarding ipv4 route vrf Customers
05-09-2020 05:23 PM
I really think you need the peer-gateway / peer-switch in the vpc domain config. I've never tried it without those, that could be it, there's some weirdness going on. At least put those in and continue. The loopbacks on sw1/sw2 should be totally pingable from any client on either sw1 or sw2 , regardless of R1.. So first get that working.
05-10-2020 01:01 AM - edited 05-10-2020 01:03 AM
I added the commands (peer-gateway, peer-switch). The result is the same.
The client1 can ping client2. So, the VXLAN bridging is working.
The client1 can ping the loopback at SW1, but not the loopbacks in SW2 and R1.
The client2 can ping the loopback in SW2 and also loopback at R1, but not the loopback in SW1.
From SW1 I cannot ping the loopback in SW2.
Flags -(Rmac):Router MAC (Stt):Static (L):Local (R):Remote (V):vPC link (Dup):Duplicate (Spl):Split (Rcv):Recv(D):Del Pending (S):Stale (C):Clear (Ps):Peer Sync (Ro):Re-Originated Topology Mac Address Prod Flags Seq No Host IP Next- Hops ----------- -------------- ------ ---------- --------------- --------------- 280 0050.7966.6803 HMM -- 0 192.168.70.10 Local 280 0050.7966.680a HMM -- 0 192.168.70.20 Local
IPv4 routes for table Customers/base ------------------+-----------------------------------------+----------------------+-----------------+----------------- Prefix | Next-hop | Interface | Labels | Partial Install ------------------+-----------------------------------------+----------------------+-----------------+----------------- 127.0.0.0/8 Drop Null0 10.10.10.93/32 Receive sup-eth1 10.10.10.193/32 192.168.93.102 nve1
10.88.88.0/24 192.168.93.102 nve1 192.168.70.0/26 Attached Vlan280 192.168.70.0/32 Drop Null0 192.168.70.1/32 Receive sup-eth1 192.168.70.10/32 192.168.70.10 Vlan280 192.168.70.63/32 Attached Vlan280
05-10-2020 01:29 AM - edited 05-10-2020 01:32 AM
I enabled the two commands (peer-gateway, peer-switch) but the result is the same.
From client1 I can ping SW1 loopback but not loopbacks on SW2 and R1.
From client2 I can ping loopbacks on SW2 and R1 but not this in SW1.
I can ping from client1 to client2, so the VXLAN bridging is working.
I cannot ping from SW1 loopback to SW2 loopback. In SW2 I capture the request but the reply is not generated.
What do you mean with "it's not being put where it should be."?
------------------+-----------------------------------------+----------------------+-----------------+----------------- Prefix | Next-hop | Interface | Labels | Partial Install ------------------+-----------------------------------------+----------------------+-----------------+----------------- 127.0.0.0/8 Drop Null0 10.10.10.93/32 Receive sup-eth1 10.10.10.193/32 192.168.93.102 nve1 10.88.88.0/32 192.168.93.102 nve1 192.168.70.0/26 Attached Vlan280 192.168.70.0/32 Drop Null0 192.168.70.1/32 Receive sup-eth1 192.168.70.10/32 192.168.70.10 Vlan280 192.168.70.63/32 Attached Vlan280
show ip route vrf Customers
IP Route Table for VRF "Customers" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 10.10.10.93/32, ubest/mbest: 2/0, attached *via 10.10.10.93, Lo888, [0/0], 09:04:29, local *via 10.10.10.93, Lo888, [0/0], 09:04:29, direct 10.10.10.193/32, ubest/mbest: 1/0 *via 192.168.93.102%default, [200/0], 09:04:29, bgp-65501, internal, tag 65501 (evpn) segid: 900001 tunnelid: 0xc0a85d66 encap: VXLAN 10.88.88.0/24, ubest/mbest: 1/0 *via 192.168.93.102%default, [200/0], 08:43:24, bgp-65501, internal, tag 65502 (evpn) segid: 900001 tunnelid: 0xc0a85d66 encap: VXLAN 192.168.70.0/26, ubest/mbest: 1/0, attached *via 192.168.70.1, Vlan280, [0/0], 09:04:29, direct 192.168.70.1/32, ubest/mbest: 1/0, attached *via 192.168.70.1, Vlan280, [0/0], 09:04:29, local 192.168.70.10/32, ubest/mbest: 1/0, attached *via 192.168.70.10, Vlan280, [190/0], 09:00:12, hmm 192.168.70.20/32, ubest/mbest: 1/0, attached *via 192.168.70.20, Vlan280, [190/0], 00:39:14, hmm
05-10-2020 10:58 AM
Need to run those commands on both switches, as you see the 'show forwarding' is what is actually programmed in the hardware, and the 10.88.88.0 is a /32 and not a /24. Although you should be able to ping both loopbacks from client1, the sw2 is probably trying to reply to client1 over the peer link (since it's an orphan port) and there might be something funky going on there. Look at the arp tables, forwarding tables, l2route mac and mac-ip on both switches.
So we need to see what is programmed in the hardware on both sw1 and sw2 to see why it's not replying.
Why don't you try it without VPC? See if that's the reason it isn't working, start from basic non vpc config and then switch to vpc config.
Did you include the ENTIRE config in your attachment? going out on a limb but did you do the 'hardware access-list tcam region arp-ether 256 double-wide ' ?
05-10-2020 11:30 AM
Thanks for answer. The loopback is announced from R1 as /24 (the IP in loopback is 10.88.88.88 255.255.255.0).
I also suppose that the problem is somewhere in vpc and with the connectivity via peerlink.
(For this reason I tried to use physical link for L3 connectivity between the switches and not a vPC VLAN as the 9396 not supports the command 'system nve infra-vlans' so I don't know if peering via vPC vlan is support for my platform.)
I forgot to mention (and I am sorry about it :-) ) that this config is taken from virtual lab (using Nexus 9000v). So the command 'hardware access-list tcam region arp-ether 256 double-wide' is not available there. I have the same setup on physical switches but it hard to make changes in production enviroment. So, I replicated the config to a virtual lab in order to investigate this problem. Due to virtual lab the 'show forwarding' command isn't available. The output is taken from the physical switches.
Without the vPC the communication is working as expected but in this case the topology and the technologies that used are very different from the original scenario (vPC, anycast VTEP etc).
I tried to use NXOS 9.2.x and 9.3.x but the result remains the same. Anyway, I can't conclude if this is a 'bug', or if I missing something.
05-10-2020 04:12 PM - edited 05-11-2020 09:30 AM
Could be cfs isn't distributing the arp entry to the other switch.. because what should happen when you ping sw2 from the client on sw1, the path should be like this:
client -> sw1 -> vxlan encap to sw2 rmac, sw2 decaps it (since it's going to sw2 rmac) and does a lookup in the vrf associated with the vni , finds that it is destined to the loopback int, and replies from that loopback by doing a lookup in the vrf associated with the loopback to find dst ip nexthop, finds the ip and associated l2route in its local database (because CFS synched up the arp entries from sw1/2 from the 'ip arp synchronize' command in VPC, finds arp entry in the vlan280 on sw2 and sends it out vlan 280 -> peer link -> sw1 -> client 1
So either, it's being blocked on the peer link? or, CFS isn't synching the arp entries. VPC fabric peering fixes all this mess but unfortunately the older switches don't support it.
So, verify the arp entries on both sides, verify cfs, sniff the traffic and see what's going over the peer link.
05-11-2020 09:49 AM
I done some tests with physical switches but I am getting some 'weird' results.
I am trying to ping from Client1(192.168.70.10) to loopback in SW2 (10.10.10.193) but am getting 'TTL expired in transit.' I capture this traffic and the srcmac is the physical MAC from SW1. So, I suppose tha the SW1 cannot find the way to forward the packet using VXLAN to SW2.
I tried to create an SVI between in two switches in vrf Customers and to establish iBGP. With this way the communication is ok. But in this case the VXLAN is not using. Maybe there is a problem with VXLAN routing?
Some command outputs: (vlan99 is temporary for tests).
SW1:
sh forwarding vrf Customers slot 1 ======= IPv4 routes for table Customers/base ------------------+-----------------------------------------+----------------------+-----------------+--------------- -- Prefix | Next-hop | Interface | Labels | Partial Instal l ------------------+-----------------------------------------+----------------------+-----------------+--------------- -- 127.0.0.0/8 Drop Null0 10.10.10.93/32 Receive sup-eth1 10.10.10.193/32 192.168.93.102 nve1 10.88.88.0/24 192.168.93.102 nve1 10.93.1.2/31 Attached Vlan99 10.93.1.2/32 Receive sup-eth1 10.93.1.3/32 10.93.1.3 Vlan99 192.168.70.0/26 Attached Vlan280 192.168.70.0/32 Drop Null0 192.168.70.1/32 Receive sup-eth1 192.168.70.10/32 192.168.70.10 Vlan280 192.168.70.63/32 Attached Vlan280
sh ip arp suppression-cache local Flags: + - Adjacencies synced via CFSoE L - Local Adjacency R - Remote Adjacency L2 - Learnt over L2 interface Ip Address Age Mac Address Vlan Physical-ifindex Flags 192.168.70.10 00:03:26 b8ac.6f86.b153 280 Ethernet1/10 L
sh ip route vrf Customers IP Route Table for VRF "Customers" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 10.10.10.93/32, ubest/mbest: 2/0, attached *via 10.10.10.93, Lo888, [0/0], 01:17:36, local *via 10.10.10.93, Lo888, [0/0], 01:17:36, direct 10.10.10.193/32, ubest/mbest: 1/0 *via 192.168.93.102%default, [200/0], 00:33:51, bgp-65501, internal, tag 65501 (evpn) segid: 900001 tunnelid: 0xc0a85d66 encap: VXLAN 10.88.88.0/24, ubest/mbest: 1/0 *via 192.168.93.102%default, [200/0], 00:22:37, bgp-65501, internal, tag 65502 (evpn) segid: 900001 tunnelid: 0xc0a85d66 encap: VXLAN 10.93.1.2/31, ubest/mbest: 1/0, attached *via 10.93.1.2, Vlan99, [0/0], 00:55:59, direct 10.93.1.2/32, ubest/mbest: 1/0, attached *via 10.93.1.2, Vlan99, [0/0], 00:55:59, local 192.168.70.0/26, ubest/mbest: 1/0, attached *via 192.168.70.1, Vlan280, [0/0], 00:55:59, direct 192.168.70.1/32, ubest/mbest: 1/0, attached *via 192.168.70.1, Vlan280, [0/0], 00:55:59, local 192.168.70.10/32, ubest/mbest: 1/0, attached *via 192.168.70.10, Vlan280, [190/0], 00:19:48, hmm
show bgp ipv4 unicast vrf Customers BGP routing table information for VRF Customers, address family IPv4 Unicast BGP table version is 35, Local Router ID is 10.0.93.101 Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-injected Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - best2 Network Next Hop Metric LocPrf Weight Path *>l10.10.10.93/32 0.0.0.0 100 32768 i *>i10.10.10.193/32 192.168.93.102 100 0 i *>i10.88.88.0/24 192.168.93.102 100 0 65502 i * i192.168.70.0/26 192.168.93.102 100 0 i *>l 0.0.0.0 100 32768 i
show bgp l2vpn evpn vrf Customers BGP routing table information for VRF default, address family L2VPN EVPN BGP table version is 37, Local Router ID is 10.0.93.101 Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-injected Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - best2 Network Next Hop Metric LocPrf Weight Path Route Distinguisher: 10.0.93.101:33047 (L2VNI 28000) *>l[2]:[0]:[0]:[48]:[b8ac.6f86.b153]:[0]:[0.0.0.0]/216 192.168.93.93 100 32768 i *>l[2]:[0]:[0]:[48]:[b8ac.6f86.b153]:[32]:[192.168.70.10]/272 192.168.93.93 100 32768 i *>l[3]:[0]:[32]:[192.168.93.93]/88 192.168.93.93 100 32768 i Route Distinguisher: 10.0.93.102:3 *>i[5]:[0]:[0]:[24]:[10.88.88.0]/224 192.168.93.102 100 0 65502 i *>i[5]:[0]:[0]:[26]:[192.168.70.0]/224 192.168.93.102 100 0 i *>i[5]:[0]:[0]:[32]:[10.10.10.193]/224 192.168.93.102 100 0 i Route Distinguisher: 10.0.93.101:3 (L3VNI 900001) *>l[2]:[0]:[0]:[48]:[7c69.f6e0.b057]:[0]:[0.0.0.0]/216 192.168.93.93 100 32768 i *>l[5]:[0]:[0]:[26]:[192.168.70.0]/224 192.168.93.101 100 32768 i *>l[5]:[0]:[0]:[32]:[10.10.10.93]/224 192.168.93.101 100 32768 i
show l2route mac-ip all Flags -(Rmac):Router MAC (Stt):Static (L):Local (R):Remote (V):vPC link (Dup):Duplicate (Spl):Split (Rcv):Recv(D):Del Pending (S):Stale (C):Clear (Ps):Peer Sync (Ro):Re-Originated (Orp):Orphan Topology Mac Address Host IP Prod Flags Seq No Next-Hops ----------- -------------- --------------- ------ ---------- --------------- 280 b8ac.6f86.b153 192.168.70.10 HMM -- 0 Local
Outputs from SW2:
sh forwarding vrf Customers slot 1 ======= IPv4 routes for table Customers/base ------------------+-----------------------------------------+----------------------+-----------------+--------------- -- Prefix | Next-hop | Interface | Labels | Partial Instal l ------------------+-----------------------------------------+----------------------+-----------------+--------------- -- 127.0.0.0/8 Drop Null0 10.10.10.93/32 192.168.93.101 nve1 10.10.10.193/32 Receive sup-eth1 *10.88.88.0/24 10.124.124.2 Ethernet1/10 10.93.1.2/31 Attached Vlan99 10.93.1.2/32 10.93.1.2 Vlan99 10.93.1.3/32 Receive sup-eth1 10.124.124.0/30 Attached Ethernet1/10 10.124.124.0/32 Drop Null0 10.124.124.1/32 Receive sup-eth1 10.124.124.2/32 10.124.124.2 Ethernet1/10 10.124.124.3/32 Attached Ethernet1/10 192.168.70.0/26 Attached Vlan280 192.168.70.0/32 Drop Null0 192.168.70.1/32 Receive sup-eth1 192.168.70.10/32 192.168.70.10 Vlan280 192.168.70.63/32 Attached Vlan280
sh ip arp suppression-cache local Flags: + - Adjacencies synced via CFSoE L - Local Adjacency R - Remote Adjacency L2 - Learnt over L2 interface Ip Address Age Mac Address Vlan Physical-ifindex Flags 192.168.70.10 00:08:16 b8ac.6f86.b153 280 port-channel93 L
sh ip route vrf Customers +IP Route Table for VRF "Customers" '*' denotes best ucast next-hop '**' denotes best mcast next-hop '[x/y]' denotes [preference/metric] '%<string>' in via output denotes VRF <string> 10.10.10.93/32, ubest/mbest: 1/0 *via 192.168.93.101%default, [200/0], 00:38:37, bgp-65501, internal, tag 65501 (evpn) segid: 900001 tunnelid: 0xc 0a85d65 encap: VXLAN 10.10.10.193/32, ubest/mbest: 2/0, attached *via 10.10.10.193, Lo888, [0/0], 01:22:04, local *via 10.10.10.193, Lo888, [0/0], 01:22:04, direct 10.88.88.0/24, ubest/mbest: 1/0 *via 10.124.124.2, [20/0], 00:27:24, bgp-65501, external, tag 65502 10.93.1.2/31, ubest/mbest: 1/0, attached *via 10.93.1.3, Vlan99, [0/0], 01:02:04, direct 10.93.1.3/32, ubest/mbest: 1/0, attached *via 10.93.1.3, Vlan99, [0/0], 01:02:04, local 10.124.124.0/30, ubest/mbest: 1/0, attached *via 10.124.124.1, Eth1/10, [0/0], 00:27:25, direct 10.124.124.1/32, ubest/mbest: 1/0, attached *via 10.124.124.1, Eth1/10, [0/0], 00:27:25, local 192.168.70.0/26, ubest/mbest: 1/0, attached *via 192.168.70.1, Vlan280, [0/0], 01:18:54, direct 192.168.70.1/32, ubest/mbest: 1/0, attached *via 192.168.70.1, Vlan280, [0/0], 01:18:54, local 192.168.70.10/32, ubest/mbest: 1/0, attached *via 192.168.70.10, Vlan280, [190/0], 00:24:34, hmm
show bgp l2vpn evpn vrf Customers BGP routing table information for VRF default, address family L2VPN EVPN BGP table version is 12, Local Router ID is 10.0.93.102 Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-injected Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup, 2 - best2 Network Next Hop Metric LocPrf Weight Path Route Distinguisher: 10.0.93.101:3 *>i[5]:[0]:[0]:[26]:[192.168.70.0]/224 192.168.93.101 100 0 i *>i[5]:[0]:[0]:[32]:[10.10.10.93]/224 192.168.93.101 100 0 i Route Distinguisher: 10.0.93.102:33047 (L2VNI 28000) *>l[2]:[0]:[0]:[48]:[b8ac.6f86.b153]:[0]:[0.0.0.0]/216 192.168.93.93 100 32768 i *>l[2]:[0]:[0]:[48]:[b8ac.6f86.b153]:[32]:[192.168.70.10]/272 192.168.93.93 100 32768 i *>l[3]:[0]:[32]:[192.168.93.93]/88 192.168.93.93 100 32768 i Route Distinguisher: 10.0.93.102:3 (L3VNI 900001) *>l[2]:[0]:[0]:[48]:[7426.ac76.500b]:[0]:[0.0.0.0]/216 192.168.93.93 100 32768 i *>l[5]:[0]:[0]:[24]:[10.88.88.0]/224 192.168.93.102 0 65502 i *>l[5]:[0]:[0]:[26]:[192.168.70.0]/224 192.168.93.102 100 32768 i *>l[5]:[0]:[0]:[32]:[10.10.10.193]/224 192.168.93.102 100 32768 i
05-11-2020 12:34 PM - edited 05-11-2020 12:40 PM
I have a lab set up with several gen1 (trident2) 9300's , I'll set up this exact scenario sometime soon and get back to you. Src mac will be the rmac of the encapsulating switch when it's routed, that's normal for anything. TTL expired means it's routing loop, so probably sw2 not getting the arp(and therefore the type 2 route /32 inserted locally) so it's sending it back to sw1 which is sending it back to sw2 which is sending it back to sw1 etc... do a traceroute instead of ping I bet that is what you will see... well that would be with pinging a client on sw2 but u are pinging loopback, so the loopback must not be inserted into the table.. I keep thinking you are trying to ping a client on sw2 not the loopback haha. So the ingress packet shouldn't loop it should terminate at the loopback, but the egress packet would loop if there was a conflicting route back to the client. Loopback wouldn't have an arp entry but would have a corresponding type 5 entry from redistribution or the network statement which should be fine. We know this works in non VPC environment. I will test with VPC when I get a chance the same setup, no reason why it shouldn't work and no reason it should give u a ttl expiry unless there's a routing loop, do a traceroute and see where it is looping.
05-11-2020 03:03 PM
OK. Thank you for your answer. I tried a traceroute from clien1 to loopback but I am seeing the default gateway IP (192.168.70.1) in every hop. I tried to capture the trace packets and I can see that arriving to SW2. I can't see if the SW2 generates an answer.
Thank you again for your time. I am awaiting for your results.
