08-17-2011 08:14 PM
In Nexus1000v, the "VM-Uplink" ethernet port profile is set to "switchport truck allowed vlan 861-863" which is using vPC-HM with four vmnics, two sub-groups, two links to one upstream, and two for the another upstream switch . But on vCenter -> Home -> Inventory -> Networking -> then select the "Uplink" profile on left column of vSphere, then select "Ports" tab on main window, it shows three vmnics within under "VM-Uplink" profile show VLAN access:861-863, but one vmnics shows VLAN access: 1.
Supposed all vmnics within that port profile will show the same VLAN access:861-863. We fould that by removed and then re-add vmnic to that port profile "VM-Uplink", the VLAN status resumed normal from VLAN 1 back to VLAN 861-863.
It is still unknown about how to trigger this.
08-26-2011 04:29 AM
Please paste your running config. Feel free to remove any sensitive information.
Robert
09-06-2011 04:17 AM
Here is the config.
Thanks.
Darren
version 4.2(1)SV1(4a)
no feature telnet
no feature http-server
feature tacacs+
username admin password 5 $XXXXXXX role network-admin
banner motd #Nexus 1000v Switch#
ssh key rsa 2048
ip domain-lookup
ip domain-lookup
tacacs-server key 7 "XXXXXXXX"
tacacs-server host X.X.X.X
aaa group server tacacs+ tacacs
server X.X.X.X
use-vrf management
source-interface mgmt0
switchname N1000V-03
ip access-list SNMP_TO_NMS
10 permit ip X.X.X.X/32 any
20 permit ip X.X.X.X/32 any
30 permit ip X.X.X.X/32 any
40 permit ip X.X.X.X/32 any
50 permit ip X.X.X.X/32 any
vem 3
host vmware id 35383339-3134-5347-4831-323058413135
vem 4
host vmware id 35383339-3134-5347-4831-323058413133
vem 5
host vmware id 34393433-3239-5347-4830-31395844324d
vem 6
host vmware id 34393433-3239-5347-4830-313958443253
snmp-server source-interface trap loopback0
snmp-server source-interface inform loopback0
snmp-server user admin network-admin auth md5 X.X.X.X priv X.X.X.X localizedkey
snmp-server host X.X.X.X traps version 2c XXXXX
snmp-server community XXXXX group network-operator
snmp-server community XXXXX use-acl SNMP_TO_NMS
ntp server X.X.X.X prefer
aaa authentication login default group tacacs
aaa authentication login console local
vrf context management
ip route 0.0.0.0/0 X.X.X.X
vlan 1,844,851,861-863,871-878
port-channel load-balance ethernet source-dest-ip-vlan
port-profile default max-ports 253
port-profile type ethernet Unused_Or_Quarantine_Uplink
vmware port-group
shutdown
max-ports 32
description Port-group created for Nexus1000V internal usage. Do not use.
state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
vmware port-group
shutdown
max-ports 32
state enabled
port-profile type ethernet VEM-Uplink
vmware port-group
switchport mode trunk
switchport trunk allowed vlan 851
cdp enable
speed 1000
duplex full
channel-group auto mode on mac-pinning
no shutdown
system vlan 851
max-ports 32
description Connection to VSM
state enabled
port-profile type ethernet UTM-VLAN-Uplink
vmware port-group
switchport trunk allowed vlan 861-863
channel-group auto mode on sub-group manual
no shutdown
max-ports 32
description Uplink profile for vlan 861-863 traffic
state enabled
port-profile type ethernet NetBackup-Uplink
vmware port-group
switchport trunk allowed vlan 844
no shutdown
max-ports 32
description Uplink profile for NetBackup-Uplink
state enabled
port-profile type ethernet FW-VLAN-Uplink
vmware port-group
switchport trunk allowed vlan 871-878
no shutdown
max-ports 32
description Uplink profile for FW-VLAN-Uplink
state enabled
port-profile type vethernet VLAN-861
vmware port-group
switchport mode access
switchport access vlan 861
no shutdown
state enabled
port-profile type vethernet VLAN-862
vmware port-group
switchport access vlan 862
no shutdown
state enabled
port-profile type vethernet VLAN-863
vmware port-group
switchport access vlan 863
no shutdown
state enabled
port-profile type vethernet VLAN-844
vmware port-group
switchport access vlan 844
no shutdown
description NetBackup Network
state enabled
port-profile type vethernet VLAN-871
vmware port-group
switchport access vlan 871
no shutdown
state enabled
port-profile type vethernet VLAN-872
vmware port-group
switchport access vlan 872
no shutdown
state enabled
port-profile type vethernet VLAN-873
vmware port-group
switchport access vlan 873
no shutdown
state enabled
port-profile type vethernet VLAN-874
vmware port-group
switchport access vlan 874
no shutdown
state enabled
port-profile type vethernet VLAN-875
vmware port-group
switchport access vlan 875
no shutdown
state enabled
port-profile type vethernet VLAN-876
vmware port-group
switchport access vlan 876
no shutdown
state enabled
port-profile type vethernet VLAN-877
vmware port-group
switchport access vlan 877
no shutdown
state enabled
port-profile type vethernet VLAN-878
vmware port-group
switchport access vlan 878
no shutdown
state enabled
vdc SVTN1000V-03 id 1
limit-resource vlan minimum 16 maximum 2049
limit-resource monitor-session minimum 0 maximum 2
limit-resource vrf minimum 16 maximum 8192
limit-resource port-channel minimum 0 maximum 768
limit-resource u4route-mem minimum 32 maximum 32
limit-resource u6route-mem minimum 16 maximum 16
limit-resource m4route-mem minimum 58 maximum 58
limit-resource m6route-mem minimum 8 maximum 8
interface port-channel1
inherit port-profile UTM-VLAN-Uplink
vem 3
description XXXXXXXX-07 UTM-VLAN-Uplink
interface port-channel2
inherit port-profile VEM-Uplink
vem 3
no shutdown
interface port-channel3
inherit port-profile FW-VLAN-Uplink
vem 3
description XXXXXXXX-07 FW-VLAN-Uplink
interface port-channel4
vem 4
interface port-channel5
vem 4
description XXXXXXXX-06 UTM-VLAN-Uplink
interface port-channel6
vem 4
description XXXXXXXX-06 FW-VLAN-Uplink
interface port-channel7
vem 5
description XXXXXXXX-03 FW-VLAN-Uplink
interface port-channel8
vem 5
interface port-channel9
vem 5
description XXXXXXXX-03 UTM-VLAN-Uplink
interface port-channel10
vem 6
description XXXXXXXX-04 FW-VLAN-Uplink
interface port-channel11
vem 6
interface port-channel12
vem 6
description XXXXXXXX-04 UTM-VLAN-Uplink
port-channel cdp-map XXXXXXXXXXXX 0
interface mgmt0
ip address XXXXXX/24
interface loopback0
ip address XXXXXX/32
interface Vethernet1
inherit port-profile VLAN-871
description XXXXXX, Network Adapter 1
vmware dvport 1500 dvswitch uuid "XXXXXX"
vmware vm mac XXXXXX
interface Vethernet2
inherit port-profile VLAN-862
vmware dvport 626 dvswitch uuid "XXXXXX"
interface Vethernet3
vmware dvport 256 dvswitch uuid "XXXXXX"
interface Vethernet4
vmware dvport 258 dvswitch uuid "XXXXXX"
interface Ethernet3/8
description XXXXXXXX-07 VEM-Uplink-XXXXXX
interface Ethernet3/9
description XXXXXXXX-07 UTM-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet3/10
sub-group-id 1
interface Ethernet3/12
description XXXXXXXX-07 FW-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet3/13
sub-group-id 2
interface Ethernet3/14
sub-group-id 2
interface Ethernet3/15
interface Ethernet3/16
sub-group-id 2
interface Ethernet4/8
description XXXXXXXX-06 VEM-Uplink-XXXXXX
interface Ethernet4/9
description XXXXXXXX-06 UTM-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet4/10
sub-group-id 1
interface Ethernet4/12
description XXXXXXXX-06 FW-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet4/13
sub-group-id 2
interface Ethernet4/14
sub-group-id 2
interface Ethernet4/15
interface Ethernet4/16
sub-group-id 2
interface Ethernet5/8
description XXXXXXXX-03 VEM-Uplink-XXXXXX
interface Ethernet5/9
description XXXXXXXX-03 UTM-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet5/10
sub-group-id 2
interface Ethernet5/12
description XXXXXXXX-03 FW-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet5/13
sub-group-id 1
interface Ethernet5/14
sub-group-id 2
interface Ethernet5/15
interface Ethernet5/16
sub-group-id 2
interface Ethernet6/8
description XXXXXXXX-04 VEM-Uplink-XXXXXX
interface Ethernet6/9
description XXXXXXXX-04 UTM-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet6/10
sub-group-id 2
interface Ethernet6/12
description XXXXXXXX-04 FW-VLAN-Uplink-XXXXXX
sub-group-id 1
interface Ethernet6/13
sub-group-id 1
interface Ethernet6/14
sub-group-id 2
interface Ethernet6/15
interface Ethernet6/16
sub-group-id 2
interface control0
clock timezone HKT 8 0
line vty
exec-timeout 5
line console
exec-timeout 1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-1
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart-mz.4.2.1.SV1.4a.bin sup-2
boot system bootflash:/nexus-1000v-mz.4.2.1.SV1.4a.bin sup-2
svs-domain
domain id 3841
control vlan 851
packet vlan 851
svs mode L2
svs connection VC
protocol vmware-vim
remote ip address X.X.X.X port 80
vmware dvs uuid "5b 58 39 50 6e 16 ef de-e1 8a 45 84 07 c5 7b 32" datacenter-name XXXXXX
max-ports 8192
connect
vsn type vsg global
tcp state-checks
vnm-policy-agent
registration-ip 0.0.0.0
shared-secret **********
log-level
N1000V-03# exit
