01-30-2012 11:14 AM
Is it possible to use Port Profiles at N1K level to classify and mark the traffic (set CoS) then let the VIC to place the packets in the right queues (configured in QoS System Class ) using the CoS in the arriving packets ?
01-31-2012 07:45 PM
Welcome to the forums!
To answer your question, YES it is possible to use.
If you are marking at the Nexus 1000v layer, the vNIC policy should be set as 'Host Control - Full' in the UCS QoS policy so that the CoS values set by Nexus 1000v are trusted and preserved by the Cisco VIC.
By default, the Cisco VIC has 'Host Control - None' meaning it will not pass the CoS values upstream. Therefore you need to make the appropriate changes and then the VMware ESX service profile must be rebooted for this function to operate correctly.
Best Practices in Deploying Cisco Nexus 1000V Series Switches on Cisco UCS B and C Series Cisco UCS Manager Servers
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9902/white_paper_c11-558242.html
However within this document, it mentions the need for the Host control in the following section:
Hope this helps.
Michael
02-02-2012 09:36 AM
Thanks for your response Michael,
So, if I want to only mark traffic at the N1K layer (for example with a CoS = 2 for a group of VMs) is it the following configuration correct ?
QoS System Class on UCS Manager
Priority = Silver ; CoS = 2 ; Weight = 10%
vNIC policy in the system profile
Host Control = Full
Nexus 1000V
policy-map type qos class-cos2
description [VM Customer1]
class class-default
set cos 2
port-profile type vethernet VMCust1
vmware port-group
service-policy type qos input class-cos2
Thanks for your help.
Michel
02-02-2012 08:20 PM
Hi Michel,
Yep that looks good.
Let me know if you need anything else.
Michael
02-08-2012 03:32 AM
Michael,
Can you tell me how I can check/monitor the Queues utilization on the VIC to verify if the packets are really placed on different queues in function of their CoS.
Many thanks,
Michel
02-09-2012 01:17 AM
Hi Michel,
I am not aware of a way to verify on the VIC itself. However, we can verify it from the Fabric Interconnect.
1) Identify the qos-group that is defined for the CoS level you are interested in.
Verify with: UCS-A(nxos)# show policy-map system
You should see something that equates to the following
best-effort should be qos-group 0
fcoe should be qos-group 1
platinum should be qos-group 2
etc
2) Identify which fabric port the server in question is using to send/receive traffic to/from the Fabric Interconnect
UCS-A(nxos)# show fex <chassis> detail
Say for example we are interested in Blade 1/1 traffic, then
UCS-A(nxos)# show fex 1 detail
FEX: 1 Description: FEX0001 state: Online
FEX version: 5.0(3)N2(2.02) [Switch version: 5.0(3)N2(2.02)]
Fex Port State Fabric Port
Eth1/1/1 Up Eth1/7 <------ Here we see that it is utilizing Eth1/7 on the Fabric Interconnect
3) Lastly, view the statistics per qos-group for this interface
UCS-A(nxos)# show queuing interface eth 1/7
qos-group 1
q-size: 76800, HW MTU: 2240 (2158 configured)
drop-type: no-drop, xon: 128, xoff: 240
Statistics:
Pkts received over the port : 465638
Ucast pkts sent to the cross-bar : 465638
Mcast pkts sent to the cross-bar : 0
Ucast pkts received from the cross-bar : 934375
Pkts sent to the port : 934375
Pkts discarded on ingress : 0
Per-priority-pause status : Rx (Inactive), Tx (Inactive)
You should see that the counters for the relevant qos-groups (matching your N1Kv marked traffic) should be incrementing.
Michael
02-21-2012 02:20 PM
Hi Michael,
thanks for this useful information.
I tried to implement QoS on NK1 and I have a new question.
I can effectively class traffic on port-profile using service-policy but for control and packet VLAN there is not an existing service profile.
I cannot use "match protocol n1k-control" with a "class-map type qos ...".
So is there a way to mark control and packet traffic with a specific CoS on the egress of the N1K ?
Michel
03-07-2012 05:35 PM
Hi Michel,
The Nexus 1000V sets the control and packet frames to COS 6, by default, so there is no configuration is necessary
The command you are trying to use "match protocol n1k-control" is to be used with a class-map of type queuing. This is related to QOS Weighted Fair Queuing on the Nexus 1000V. More details regarding this feature is available via the following:
https://supportforums.cisco.com/docs/DOC-15079
Hope that helps to clear things up for you.
Michael
