Data Center Switches
HI, I deleted a zone that was never brought up to the activation pane. I then checked to see if the zone was deleted, and all zones disappeared for that VSAN. I cancelled out of it, check and the zones are still there. When I went into the vsan to ed...
I think there is some error on the next document:https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus9000/103x/upgrade/cisco-nexus-9000-nx-os-software-upgrade-downgrade-guide-103x/m_converting_from_cisco_nx-os_to_aci_mode_10x.htmlI tried the procedu...
mplaksin0 by Level 1
  • 24 Views
  • 0 replies
Hello colleagues! There is a question in terms of Data center design. My current customer would like to save a money (often case, right?) and interested in using only 4 nodes in minimal configuration instead of 6. Initially I suggested 2 spines, 2 le...
Hello as per the  below topology. I have two questions.1) When S1 sends the broadcast traffic for S2, through which link the broadcast will go?2) Also, when the broadcast reaches S2 it can send the same broadcast back to S1 as both the servers are co...
