" show switch edition " not valid
lamnguyen2010
thank you for reading this post.
I'm currently having an issue with nexus 1000v. the commands "show switch edition" or "svs switch edition" were not valid from the CLI of the 1000v console.
n1000v-1# sh sw?
  switchname  Show the system's hostname
n1000v-1(config)# svs ?
  connection  Configure connection information
  license     Global License Configuration
  upgrade     Configure upgrade vsm information
  veth        Configure a virtual ethernet global policy
Please advise
running config:
n1000v-1# sh run
!Command: show running-config
!Time: Mon Jul  8 16:16:53 2013
version 4.2(1)SV1(5.2)
feature telnet
feature lacp
username ad role network-admin
banner motd #Nexus 1000v Switch#
ssh key rsa 2048
ip domain-lookup
ip host n1000v-1 10.4.254.250
switchname n1000v-1
errdisable recovery cause failed-port-state
vem 3
  host vmware id 12d2da52-a3d7-11e1-a6ca-a44c11de1ba4
vem 4
  host vmware id 166f9488-a2e4-11e1-a7e2-a44c11de092c
vem 5
  host vmware id 4fe26bec-a2d8-11e1-be9b-a44c11de085a
vem 6
  host vmware id 59f37584-a24b-11e1-ab40-a44c11ddfcf6
snmp-server user
snmp-server user
vrf context management
  ip route 0.0.0.0/0 10.4.254.254
vlan 1,10,30,81-84,110,254
vlan 1,10,30,81-83
vlan 84
  name n1kv-p&c
vlan 110
  name Voice_Servers
vlan 254
lacp offload
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type ethernet system-uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 1-3967,4048-4093
  mtu 9000
  switchport trunk native vlan 84
  channel-group auto mode active
  no shutdown
  system vlan 81-82,84,254
  state enabled
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type vethernet SVRS_VLAN
  vmware port-group
  switchport mode access
  switchport access vlan 30
  no shutdown
  description Servers VLAN
  state enabl
port-profile type vethernet USERS_VLAN1
  vmware port-group
  switchport access vlan 10
  no shutdown
  description Wired Data Network
  state enabled
port-profile type vethernet VSRVS_VLAN11
  vmware port-group
  switchport access vlan 110
  no shutdown
  state enabled
port-profile type vethernet Mgt_VLAN254_10.4.254
  vmware port-group
  switchport access vlan 254
  no shutdown
  system vlan 254
  description Management Network
  state enabled
port-profile type vethernet iSCSI-1_VLAN81_10.4.81
  vmware port-group
  switchport access vlan 81
  no shutdown
  system vlan 81
  state enabled
port-profile type vethernet iSCSI-2_VLAN82_10.4.82
  vmware port-group
  switchport access vlan 82
  no shutdown
  system vlan 82
  state enabled
port-profile type vethernet vMotion_VLAN83_10.4.83
  vmware port-group
  switchport access vlan 83
  no shutdown
  description vMotion VLAN (Non-Routed)
  state enabled
port-profile type vethernet n1kv-p&c_VLAN84_10.4.84
  vmware port-group
  switchport access vlan 84
  no shutdown
  system vlan 84
  state enabled
vdc tm-n1000v-1 id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 1 maximum 1
  limit-resource u6route-mem minimum 1 maximum 1
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface port-channel1
  inherit port-profile system-uplink
  vem 3
interface control0
line console
boot kickstart bootflash:/nexus-1000v-kickstart.4.2.1.SV1.5.2.bin sup-1
boot system bootflash:/nexus-1000v.4.2.1.SV1.5.2.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart.4.2.1.SV1.5.2.bin sup-2
boot system bootflash:/nexus-1000v.4.2.1.SV1.5.2.bin sup-2
svs-domain
  domain id 201
  control vlan 84
  packet vlan 84
  svs mode L2
svs connection
  protocol vmware-vim
  remote ip address 10.4.254.236 port 80
  vmware dvs uuid "f3 6f 37 50 47 92 35 ad-ef 8f 91 15 4d e9 cf 32" datacenter-name ProductionDC
  max-ports 8192
  connect
vservice global type vsg
  tcp state-checks
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
thanks again
lwatta
You are running 1.5.2 code. We introduced the Essential and Advanced Editions in the 2.1 code. You will need to upgrade to 2.x code to get the "show switch edition" command to work and to have access to the different license models.
louis
thank you !!
