Redundant Paths w/ CNAs and Nexus 1000v (w/ FCoE)
nashwj
Background:
Installing some ESX 4.0 servers using Emulex CNAs connected to Nexus 5020s.  We're also using the Nexus 1000v.  Each server has two CNAs (single port) with each one connected to a different Nexus 5K.  We are using the 5K and CNAs for both 10Gb Ethernet and FCoE.  What's the best way to do redundant paths?
I can't do vPC.  If I put the two connections from a server in to a vPC I can't bind a vFC to it. The 5K won't let me.  So I thought I'd use vPC-HM on the 1000v side.  But, am I correct in reading that if you do this you still have to put each port in a channel-group on the 5K side by itself?  If so, that won't work either due to the vFC issue.
If I just uplink both CNAs to the same system-uplink profile I can't duplicate frames (and a loop).
What are my options?
pfazzone
I believe that VPC-HM should work for you in this case, since the N1K is handling the ethernet side of things before the FCoE traffic gets muxed with the Ethernet traffic in the CNA.  I have asked a few experts to chime in for a more detailed answer.  Thanks!
pf
marcodb
I'm not sure why you say:
vFCs can be bound to virtual port channels. Maybe you're trying to bind the vFC
to the physical members of the vPC. Have you tried to bind the vFC to the port
channel itself (the logical port)? When a virtual Port Channel exists, the vFC
must be bound to the virtual Port Channel, not to the member ports. Note that
only the physical ports on the local switch will be used for the vFC
You can find more information here:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_1/Cisco_Nexus_5000_Series_Switch_CLI_Software_Configuration_Guide_chapter31.html#task_12735881956
