07-14-2020 01:08 AM
I'm trying to see if there's a way to SPAN a port on Nexus 9300 to a destination port on Catalyst 3750X. I think I've reached a road block in that the Catalyst supports only RSPAN VLAN, while it seems that the Nexus only supports ERSPAN and can't even create a Remote Span VLAN.
Is that correct or am I missing something? NX-OS documentation suggests it's possible, but I've seem community comments saying RSPAN isn't supported on the N9Ks.
Any workarounds possible?
Thanks, Tony S
Solved! Go to Solution.
07-14-2020 08:36 PM
07-14-2020 08:36 PM
07-15-2020 12:32 AM
@Francesco Molino wrote:
You can configure erspan on Nexus and put your wireshark machine ip as destination.
That is the answer! I just set it up and confirmed it's working.
07-15-2020 05:22 PM
