I recently install Nexus 1000v but due to an IP address mistake, installation failed and I had to reinitialize my ESxi.
After that, I remove my Nexus 1000v VSM virtual machine because I don't want to risk to start it with the bad IP configuration.
But now, I can't remove the folder of my switch in the Networling page of vSphere Client.
Did someone can help me to remove this folder ??
Thanks a lot for your help ans sorry for mistakes, I'm a french student.
Benoit
If you want to remove the Nexus 1000V from vCenter you have to issue "no vmware dvs" from the svs connection on the VSM.
Follow the directions on how to remove and orphaned DVS in the Nexus 1000V troubleshooting guide. That's the only way to remove that folder. If you are just testing it won't hurt to leave the folder.
http://www.cisco.com/en/US/products/ps9902/prod_troubleshooting_guides_list.html
louis
Thanks for your answer.
Because I've remove my VSM VM, my only solution is to leave the folder!
Benoit
