Remove the overdraft licenses on nexus1000v
fedcre
Hi all,
after an upgrade to SV2(2.2) , i have my 19 vem modules changed the uuid , so i have 38 vem modules  , with the first 19 missing..
I transfer the first 19 licences to the pool and then i removed the old uuid vem ( conf t  no vem 3 - no vem 18). During the migration process 6 overdraft licences were used. Now ( after the vem remotion) i've free licenses, but the overdraft are stiil used!! Is possibile to remove the overdraft, using the installed licences of the pool? Or can i leave the overdraft licences on the vem without problems ? Now i'm not using the advanced feature, but in the future i wish to use.
Is there eventually a manner to see the vems(3) using the overdraft?, so i can remove the vem (removing the hosts from the dvs), delete the vem, and then put newly the hosts in the dvs, with a new vem number , hoping they take the installed licences and not the overdraft...
dv-nexus01# sh license usage  NEXUS1000V_LAN_SERVICES_PKG
Feature Usage Info
       Installed Licenses : 64
    Default Eval Licenses : 0
   Max Overdraft Licenses : 16
Installed Licenses in Use : 32
Overdraft Licenses in Use : 6
  Default Eval Lic in Use : 0
   Default Eval days left : 0
      Licenses Available : 42
          Shortest Expiry : Never
dv-nexus01# sh  module vem missing
No missing module found.
dv-nexus01# sh switch edition
Switch Edition: Advanced
Advanced Features
Feature Name    Feature State
cts             disabled
dhcp-snooping   disabled
vxlan-gateway   disabled
Licenses Available: 42
Licenses In Use: 38
License Expiry Date: Never
dv-nexus01# sh module vem license-info
Licenses are Sticky
Mod   Socket Count   License Usage Count   License Version   License Status
19    2              2                     1.0               licensed
20    2              2                     1.0               licensed
21    2              2                     1.0               licensed
22    2              2                     1.0               licensed
23    2              2                     1.0               licensed
24    2              2                     1.0               licensed
25    2              2                     1.0               licensed
26    2              2                     1.0               licensed
27    2              2                     1.0               licensed
28    2              2                     1.0               licensed
29    2              2                     1.0               licensed
30    2              2                     1.0               licensed
31    2              2                     1.0               licensed
32    2              2                     1.0               licensed
33    2              2                     1.0               licensed
34    2              2                     1.0               licensed
35    2              2                     1.0               licensed
36    2              2                     1.0               licensed
37    2              2                     1.0               licensed
admin11111
Level 4
Level 4
You can't remove overdraft licenses specifically, they won't hurt even if they stay there or are being used instead of regular licenses, meaning there are still regular licenses available and system is using overdraft licenses instead, it will still be ok
