Highlighted
Contributor
Replace Nexus 5596 by Nexus 9300
Hello!
I want to replace two Nexus 5596 by new 9300.
I have HP B22 blade switches.
Can this blade switches work with Nexus-93180yc-fx?
May be You recommended other model?
We use simple installation: L3 routing (EIGRP) and port-channels (vpc).
We do not used FC and FCoE.
Thank You!
Helping seriously ill children, all together. All information about this, is posted on my blog
6 REPLIES 6
Highlighted
Beginner
Re: Replace Nexus 5596 by Nexus 9300
Hi @Oleg Volkov ,
Unfortunately, the B22HP is a FEX, and it only supports N5K, N6K, N7K families as parent.
Depending on your sizing and budget plans, it may be better to replace your B22 with Virtual Connect modules, and then leverage new N9K switches.
Remi Astruc
Highlighted
Contributor
Hmm.
But this document say - same 9000 support FEX:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/hw/interoperability/fexmatrix/fextables.html
Highlighted
Beginner
Ha! Interesting.
I found that B22 Datasheet stating only N5K, 6K, 7K support:
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-b22-blade-fabric-extender/data_sheet_c78-685265.html
But it may not have been updated since N9K releases.
Sorry for that!
Remi Astruc
Highlighted
Contributor
I will post result after install but it may be in next year
Highlighted
You shouldn't have a problem. It's good that you checked that compatibility matrix because that is kept up to date.
The features you use on the 5K today will translate over well for the N9K.
Good luck with your upgrade!
Highlighted
Contributor
Thank You
