Cisco has announced nexus 5696Q as EOS/EOL from May 2021 and has replaced 2 Nexus 9K switches as replacement.
Using "N9K-C93360YC-FX2" for 10G ports , which supports Fex
Using "N9K-C9364C-GX"for 40G ports, which does not support fex
what Nexus 9300 switch can i buy as a Fex Aggregation for my Nexus 2K, that all ports are 40G/100G , instead of buying nexus 5696Q that is going to be EOS/EOL .
the only option that i saw was : "N9K-C9336C-FX2" (36 X 40/100G)
But this is not recommended inside this page:
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/eos-eol-notice-c51-743752.html
Is it possible to use it?
any problems?
any bugs?
any implementation problem?
