1515
reynaldo.lopez
Beginner
RSPAN (Port Mirroring) Between Switch Nexus and Other vendor Switch
I need to perform a Port mirroring from a source in one Aruba HPE Switch, crossing other Aruba HPE switch and then ending in two Nexus switches.
I know there is the option of RSPAN to perform Port mirroring between different devices in Cisco switches. And Aruba has its own VLAN port mirroring commands too.
I would like to know if someone got this to work or if it's even possible to perform this kind of Port mirroring in a multivendor environment.
Note that source port and destination port are in the same VLAN, and the intermediate switch is the Core switch of the Network. Connection between Aruba switches is a trunk Port, and between Aruba and Cisco Nexus is a Port-channel.
Diagram:
Source Device<Aruba Switch>Trunk<<Aruba Core Switch>Port-channel<Cisco Nexus>End device
Thank you in advanced for your feedback!
1 REPLY 1
Dawei
RSPAN is not supported on Nexus platform, so if the source device supports ERSPAN, it will be a good choice.
