show tcp statistics
techmail4sam
There is a command "show tcp statistics" to get tcp statistics.
whether this tcp statistics are of VSM or it includes tcp statistics of VSM+VMs on ESX.
D V
8 Replies 8
ashwinds
These are the TCP statistics of the VSM only and does not include the stats for the VEM or VMs on the ESX
-- Ashwin
How can I get TCP statistics for VMs on VEM?
Should I use Netflow or ERSPAN? or
Is there any other way to get the same?
D V
Following configuration can be used to get tcp statistics for VMs:
flow record protocol-stats
match ip protocol
collect counter bytes
collect counter packets
flow exporter exp
  destination <collector-ip>
flow monitor protocol-stats
  exporter exp
By using above config you should be able to collect protocol-wise stats for all the interfaces on a VM. You can put following config in a port profile or directly on the interface which you want to monitor:
ip flow monitor protocol-stats input
ip flow monitor protocol-stats output
This would monitor traffic in both egress and ingress with respect to VM.
-Shachi
aj3878121
The "show tcp statistics" command typically provides TCP stats for the VSM only, not including VMs on an ESX server. For VM statistics, you'll need to run commands directly within each VM or use a comprehensive monitoring tool.
iquah9oozil
These statistics help in diagnosing issues like congestion, connection drops, or suboptimal configurations, enabling targeted interventions to enhance network efficiency.
hashirr0099
The command "show tcp statistics" provides TCP statistics that are generally related to the entire ESX host, which includes both the VSM (Virtual Supervisor Module) and the VMs running on the ESX host. This means the statistics cover TCP connections and performance metrics for all traffic passing through the ESX host, encompassing both the VSM and any virtual machines.
If you need statistics specific to only the VSM or individual VMs, additional commands or filters might be required, depending on the management tools and interfaces you are using. Receiptify spotify
I hope this helps! Let me know if you need further clarification.
theliteblue57
There's a command called "show tcp statistics" for retrieving TCP statistics. Could you clarify if these statistics pertain only to VSM or if they include TCP statistics for both VSM and VMs on ESX?
theliteblue.com
habefo8793
Understanding how to "show TCP statistics" is essential for network troubleshooting and performance monitoring. www.paybyplatema.com
