10-16-2018 01:04 PM
Hi Several ports in Nexus 2K cannot be up and a few of them(unplugged) keep amber lights. Is this hardware issue or other? Thanks
10-17-2018 08:30 AM
Which specific FEX do you have? If that's an SFP FEX have you checked the SFP compatibility? Provide us a "show interface status" and a couple of "show interface X/X".
The amber led is normal on unplugged SFPs, if you shut the port down the light will vanish.
HTH,
ADP
10-17-2018 11:27 AM - edited 10-17-2018 11:33 AM
thank you so much for your reply. It's not SFP port, its port for rj45. Please see the below
FEX: N2K-C2232TM-E-10GE
N5K# sh interface e232/1/1
Ethernet232/1/1 is down (Link not connected)
Hardware: 1000/10000 Ethernet, address: 0c85.2511.1142 (bia 0c85.2511.1142)
MTU 1500 bytes, BW 0 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
auto-duplex, auto-speed
Beacon is turned off
Input flow-control is off, output flow-control is on
Switchport monitor is off
EtherType is 0x8100
Last link flapped 179week(s) 6day(s)
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
8746905008 unicast packets 0 multicast packets 2320245 broadcast packets
8749237855 input packets 8935176099607 bytes
0 jumbo packets 0 storm suppression bytes
12439 runts 0 giants 163 CRC 0 no buffer
12602 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
4889384323 unicast packets 66352211 multicast packets 18543497 broadcast packets
4974280031 output packets 1979775745180 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
13 interface resets
N5K# sh interface status | i 232/1/1
Eth232/1/1 -- notconnec 262 auto auto --
10-17-2018 12:53 PM
Have you tried to set the speed/duplex manually?
If you have any port working on the FEX you could try to put that device on 232/1/1 just to make sure that there are no hardware problems.
ADP
10-18-2018 06:39 AM - edited 10-18-2018 05:58 PM
10-18-2018 11:22 PM
This is expected behavior when a port is shutdown in the config regardless of whether there's something plugged in or not.
Off = Interface is no shut but link is down.
Green = Interface is no shut & up
Sold Amber = Interface is shut
