07-09-2019 05:40 AM
Hello i am trying to upgrade a Nexus 9000 from version
Current: 7.0(3)I5(2)
Future: 7.0(3)I7(6) That it is the current suggested.
The problem is the following: i am affected with bug CSCve24965 . And with the step one of the work around says to perform the command
Steps
1. From 7.0(3)I5(2) -> `install all nxos` to 7.0(3)[I6 or I7](x)
The question after see the bug is mandatory to perform the command install all nxos twice? the first step no should be with bios-force parameter?
¿Is possible to upgrade with an alternative method with not disruption?
Cheers
Solved! Go to Solution.
07-15-2019 12:46 AM
SOLVED : I applied the workdaround susccesfully
1. step :install all nxos bootflash:XXXXfile.bin
After that you will see the sistem upgraded but the bios no with the version 8.32
2. type command just install all nxos (without filename)
Now the system re-install all (bios incluided) After that you will see the message bios:8.35 Last 8.32) the bios is no installed but not activated
3. Reload the switch
Now you will see the current bios 8.35 installed and working.
In my case with the reload some proceess for example EIGRP vlan instace no syncroniced automatically, I had need to resyncronize manually.
Cheers.
07-10-2019 04:53 AM
After read release notes i am having doubts Please Help
07-15-2019 12:46 AM
Cheers.
