Beginner
URGENT after port change one nexus DOWN
Hi all,
after port change from fc to ethernet and restared N5K I have a problem with second N5K, this two devices are connected via peer-link and I´m receiving error log:
%VPC-2-VPC_DELAY_RESTORE_TIMER: Delay restore tim
er will be overwritten to 150 sec when l3 is installed. Old value:(150)
2019 Sep 17 04:59:31NX1 %VPC-2-VPC_SUSP_ALL_VPC: Peer-link going down, su
spending all vPCs on secondary
%STP-2-DISPUTE_DETECTED: Dispute detected on port
port-channel1 on MST0000D
configuration which I changed:
slot 1
port 33-48 type ethernet
then I set it back
slot 1
port 33-48 type fc
Problem is, that when I run second N5K primary not working and it looks like it is because of some spanning tree issue, when I have checked sh int trunk command there were problem with: Vlans Err-disabled on Trunk.
If you need more information, of configuration please let me know.
Now I´m in state, that my interfaces are down.
Thank you
Content for Community-Ad
August's Community Spotlight Awards
