Urgent need to Provision Ethernet ports on a 7K VDC
RWSdude
I have the maximum VDCs on a 7K and need to reallocate that VDC to support f2 fe card from m1 f1 type.  I need to know if this will be service affecting to the rest of the switch?   Assume that I would need to:
no allocate interface Ethernet1/10-12,Ethernet1/41
no limit-resource module-type m1 f1 m1xl m2xl
limit-resource module-type f2 f2e
allocate interface Ethernet2/1-48
Thanks in advance!
Sergiu.Daniluk
Hi @RWSdude
Apart of the impact on ports Ethernet2/1-48 and all M1/F1 ports allocated to the respective VDC subject to change, there should be no impact on the rest of the VDCs/ports.
Sergiu
Sergiu.Daniluk
Hi @RWSdude
Sergiu
Thanks, Sergiu.
I assume all the commands I listed are correct and in the right order?
So the removed ports return to the unallocated VDC 0, specifically ports 10-12 & 41?  What happens when I reallocate them to module 1, they will return to mod 1 in a shutdown state with no impact to mod 1?
Thanks.
All configuration is lost when moving ports between VDC and they will be in shutdown state.
There's documentation about this here:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/vdc/config/cisco_nexus7000_vdc_config_guide_8x/managing-vdc.html
