ā03-11-2013 03:47 AM
Hi ,
Please can i have some guidance.
Current Setup
2 x 4507R core switches with 1 HP Server cluster with passthru modules (Please see attached diagram)
4 x ESXi hosts on the cluster.
ESXi hosts disconnect and VM's become isolated, this only happens to one of the four ESXi hosts ( 3 working fine , one gets disconnected)
Checked ports and cabling connecting to uplink switches no disconnects found.
The hosts seem to disconnect for 6-30 seconds and then get reconnected.
Please see errors from VSM log
2013 Mar 8 14:02:25 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 5 (heartbeats lost)
2013 Mar 8 14:57:17 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 5 (heartbeats lost)
2013 Mar 11 08:03:20 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:04:14 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:04:39 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:33:08 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:38:48 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:39:53 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:05:19 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:07:13 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:07:40 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:10:09 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:12:18 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: Ethernet7/1 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel5: first operational port changed from Ethernet7/1 to Ethernet7/2
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: Ethernet7/2 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel5: first operational port changed from Ethernet7/2 to Ethernet7/3
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet7/1 is down (module removed)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel5 is down (No operational members)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet7/2 is down (module removed)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: Ethernet7/3 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: port-channel5 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel5: first operational port changed from Ethernet7/3 to none
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet7/3 is down (module removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet7/1 is down (Interface removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet7/2 is down (Interface removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet7/3 is down (Interface removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-MOD_OFFLINE: Module 7 is offline
[7m--More-- [m
2013 Mar 11 09:07:20 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_DETECTED: Host kmdesxprh04 detected as module 7
2013 Mar 11 09:07:25 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-MOD_ONLINE: Module 7 is online
2013 Mar 11 09:07:28 VSM1A_KINGSMEAD_BFL %VIM-5-IF_ATTACHED: Interface Vethernet19 is attached to vmk0 on port 1 of module 7 with dvport id 129
UPLINK config
Current configuration : 333 bytes
switchport trunk allowed vlan 2-4094
switchport mode trunk
speed 1000
duplex full
qos trust dscp
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
end
The disconnects randomly affect all the ESXi hosts. But only affects one host at a time.
Message was edited by: Jayendra Moodley
ā03-11-2013 05:34 AM
Please attach your VSM config and the 4500 port config for the uplinks (If they're all identical, just include one)
Robert
ā03-11-2013 06:22 AM
Hi Robert,
I have added the VSM config to the discussion.
ā03-11-2013 06:36 AM
Please also paste the relevant 4500 interface config where the VEMs uplink to. If they're all identical, one will do.
Robert
ā08-27-2014 06:38 AM
Dear all,
Did you find any resolution to that situation ?
Thx
