Various ESXi Hosts lose connectivity - VEM Heartbeat loss on Nexus 1000v 4.2.1 SV4a
jay.moodley
Hi ,
Please can i have some guidance.
Current Setup
2 x 4507R core switches with 1 HP Server cluster with passthru modules (Please see attached diagram)
4 x ESXi hosts on the cluster.
ESXi hosts disconnect and VM's become isolated, this only happens to one of the four ESXi hosts ( 3 working fine , one gets disconnected)
Checked ports and cabling connecting to uplink switches no disconnects found.
The hosts seem to disconnect for 6-30 seconds and then get reconnected.
Please see errors from VSM log
2013 Mar  8 14:02:25 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 5 (heartbeats lost)
2013 Mar  8 14:57:17 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 5 (heartbeats lost)
2013 Mar 11 08:03:20 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:04:14 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:04:39 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:33:08 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:38:48 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 08:39:53 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:05:19 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:07:13 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:07:40 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:10:09 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:12:18 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_REMOVE_NO_HB: Removing VEM 7 (heartbeats lost)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: Ethernet7/1 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel5: first operational port changed from Ethernet7/1 to Ethernet7/2
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: Ethernet7/2 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel5: first operational port changed from Ethernet7/2 to Ethernet7/3
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet7/1 is down (module removed)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel5 is down (No operational members)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet7/2 is down (module removed)
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: Ethernet7/3 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel5: port-channel5 is down
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel5: first operational port changed from Ethernet7/3 to none
2013 Mar 11 09:07:14 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_MODULE_REMOVED: Interface Ethernet7/3 is down (module removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet7/1 is down (Interface removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet7/2 is down (Interface removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %ETHPORT-5-IF_DOWN_INTERFACE_REMOVED: Interface Ethernet7/3 is down (Interface removed)
2013 Mar 11 09:07:15 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-MOD_OFFLINE: Module 7 is offline
[7m--More-- [m
2013 Mar 11 09:07:20 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-VEM_MGR_DETECTED: Host kmdesxprh04 detected as module 7
2013 Mar 11 09:07:25 VSM1A_KINGSMEAD_BFL %VEM_MGR-2-MOD_ONLINE: Module 7 is online
2013 Mar 11 09:07:28 VSM1A_KINGSMEAD_BFL %VIM-5-IF_ATTACHED: Interface Vethernet19 is attached to vmk0 on port 1 of module 7 with dvport id 129
UPLINK config
Current configuration : 333 bytes
switchport trunk allowed vlan 2-4094
switchport mode trunk
speed 1000
duplex full
qos trust dscp
no snmp trap link-status
spanning-tree portfast
spanning-tree bpduguard enable
end
The disconnects randomly affect all the ESXi hosts. But only affects one host at a time.
Message was edited by: Jayendra Moodley
Robert Burns
Please attach your VSM config and the 4500 port config for the uplinks  (If they're all identical, just include one)
Robert
Hi Robert,
I have added the VSM config to the discussion.
Please also paste the relevant 4500 interface config where the VEMs uplink to.  If they're all identical, one will do.
Robert
admin11111
Level 4
Level 4
Dear all,
Did you find any resolution to that situation ?
Thx
