09-19-2011 11:23 AM
Discosure: I am on the VMware side of the house helping our Network guys with the transition. I have a few install questions.
09-20-2011 11:14 AM
1. There shouldn't be any problems, just ensure your Java is up to date, flush the Java Cache (Control Panel - Java) and restart the install. If you still have issues let me know, or you can try the manual install method also.
2. Yes, for the VSM installation you'll need Administrator access. There's an extension key that requires admin permissions to register.
3. Your heirarchy can be anything you want under the same Datacenter. Only hosts within the same DC can be added to the same 1000v.
4. Only access is Port 80/443 - depending what you're using in the svs connection parameters. Please see my other post for more information on Ports used with 1000v communication: https://supportforums.cisco.com/thread/2070391
Robert
