Highlighted
Contributor
VEM installation: Compatible vib not found on VSM
Hello all,
I have an issue with the installation of the VEM. The VSM installation went fine and it can communicate with vCenter.
Below you have some information that you may require:
vSphere 5.1.0 (Trial)
Nexus 1000v - 4.2.1.SV1(5.2b) (Evaluation)
The configuration is pretty simple, 1 server with vCenter + 2 servers with ESXi 5.1.0
I did attempt to install VEM with the graphical java interface and it creates a longer log which ends with the following details (I assume this is important)
Jan 02, 2013 6:36:49 PM com.cisco.n1kv.installer.wizard.VemSummaryPage$LoadData start
INFO: File locationhttp://172.31.82.36/cisco/CISCO-VEM500-4.2.1.1.5.2b.0-3.0.1-metadata.zip
INFO: vib20/cisco-vem-v147-esx/Cisco_bootbank_cisco-vem-v147-esx_4.2.1.1.5.2b.0-3.0.1.vib
Jan 02, 2013 6:36:49 PM com.cisco.n1kv.installer.VCHelper checkConnection
INFO: VC Session checked: active
Jan 02, 2013 6:36:50 PM com.cisco.n1kv.installer.VCHelper patchHost
INFO: Vib NOT installed, continue with installation
Jan 02, 2013 6:36:53 PM com.cisco.n1kv.installer.VCHelper patchHost
SEVERE: Compatible vib not found on VSM
SEVERE: Installing VEM...failed
Jan 02, 2013 6:36:53 PM com.cisco.n1kv.installer.wizard.VemSummaryPage$LoadData start
INFO: Deleting VEM files from tmp directory ...
IP addresses used:
172.31.82.35 - vCenter
172.31.82.36 - VSM
172.31.82.31 - Esxi-1
172.31.82.32 - Esxi-2
Attached you have also the VSM configuration and the output of some commands that I think should be useful.
Now, that error let me understand that either the installation wizard cannot get / download the vib or that the vib is there but not compatible (with what?). First part, how it cannot download the vib if I have connectivity?! Second, if there is something not compatible, then it should be listed here:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_2_1_s_v_1_5_2_b/compatibility/information/n1000v_compatibility.html which is not.
I'm a litle bit lost. Any suggestions will be appreciated.
Thank you!
Cheers,
Calin
0 REPLIES 0
