W have Cisco Nexus N3K-C3548P-10GX switches in the data center access. All ESXi hosts in VxRail infrastructure are generating this alarm on the vCenter:
high pNIC error rate being detected
Switch interfaces are all similar. There are output drops but other than that nothing significant. I am wondering what could be the reason.
Ethernet1/1 is up
admin state is up, Dedicated Interface
Hardware: 100/1000/10000/40000 Ethernet, address: 2c33.11db.ab68 (bia 2c33.11db.ab68)
MTU 9216 bytes, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is trunk
full-duplex, 10 Gb/s, media type is 10G
Beacon is turned off
Auto-Negotiation is turned on FEC mode is Auto
Input flow-control is off, output flow-control is off
Auto-mdix is turned off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
EEE (efficient-ethernet) : n/a
admin fec state is auto, oper fec state is off
Last link flapped 1d10h
6 interface resets
Load-Interval #1: 30 seconds
30 seconds input rate 34368 bits/sec, 10 packets/sec
30 seconds output rate 160832 bits/sec, 180 packets/sec
input rate 34.37 Kbps, 10 pps; output rate 160.83 Kbps, 180 pps
Load-Interval #2: 5 minute (300 seconds)
300 seconds input rate 47296 bits/sec, 1 packets/sec
300 seconds output rate 228832 bits/sec, 107 packets/sec
input rate 47.30 Kbps, 1 pps; output rate 228.83 Kbps, 107 pps
RX
95907085 unicast packets 529555 multicast packets 25588 broadcast packets
96462228 input packets 42897130756 bytes
152281 jumbo packets 0 storm suppression packets
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
154736883 unicast packets 172708906 multicast packets 283597479 broadcast packets
611043268 output packets 122777584139 bytes
1067996 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 51984 output discard
0 Tx pause
