603
abimadaro4462
Beginner
vPC & OSPF
I have the following scenario, two nexus 9K are configured as vPC peers with HSRP, the upstream is connected to active/standby firewall with OSPF configured.
below is the configuration;
SW1 & SW2
router ospf 1
bfd
router-id 10.10.10.4
area 0.0.0.4 nssa no-summary
interface Vlan20
ip ospf dead-interval 3
ip ospf hello-interval 1
ip ospf network point-to-point
ip router ospf 1 area 0.0.0.4
ip ospf bfd
interface Vlan20
hsrp 20
ip 20.20.20.1
vpc domain 10
peer-switch
role priority 100
peer-keepalive destination 10.10.10.2 source 10.10.10.1 vrf vpcvrf
peer-gateway
layer3 peer-router
auto-recovery
ip arp synchronize
interface port-channel1
vpc peer-link
Switch one neighbor is flapping between EXSTART and EXCHANG
Neighbor ID Pri State Up Time Address Interface
10.10.10.5 1 FULL/ - 00:25:17 20.20.20.3 Vlan20
10.20.10.10 1 EXCHANGE/ - 0.065025 20.20.20.6 Vlan20
Please advice if the above configuration is correct.
3 REPLIES 3
balaji.bandi
VIP Master
To understand the problem better, can you post the HLD and how interface connected and full config of both the switches ?
BB
How to Ask The Community for Help
Here's the HLD
Here's the configuration;
SW 1
vpc domain 10
peer-switch
peer-gateway
layer3 peer-router
interface Vlan1
no ip redirects
no ipv6 redirects
interface Vlan172
no shutdown
no ip redirects
ip address 172.16.8.5/29
no ipv6 redirects
ip ospf dead-interval 40
ip router ospf 1 area 0.0.0.0
switchport mode trunk
spanning-tree port type network
vpc peer-link
interface port-channel10
switchport trunk allowed vlan 172
vpc 10
interface Ethernet1/1
no switchport
vrf member vpcvrf
ip address 10.10.10.1/30
no shutdown
interface Ethernet1/2
channel-group 1 mode active
interface Ethernet1/3
interface Ethernet1/4
channel-group 10
router ospf 1
router-id 10.10.10.1
SW2
vpc domain 10
peer-switch
peer-keepalive destination 10.10.10.1 source 10.10.10.2 vrf vpcvrf
peer-gateway
layer3 peer-router
interface Vlan1
no ip redirects
no ipv6 redirects
interface Vlan172
no shutdown
no ip redirects
ip address 172.16.8.4/29
no ipv6 redirects
vpc peer-link
vpc 10
no switchport
vrf member vpcvrf
ip address 10.10.10.2/30
no shutdown
channel-group 10
router ospf 1
router-id 10.10.10.2
Here's the output of show ip ospf neighbor
10.10.10.1 1 FULL/DR 08:49:38 172.16.8.5 Vlan172
10.20.10.10 1 EXSTART/DROTHER 00:00:01 172.16.8.1 Vlan172
I have deleted the HSRP configuration for testing but same results.
paul driver
VIP Mentor
Duplicate post  - here
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
