12-12-2019 01:02 PM
I have the following scenario, two nexus 9K are configured as vPC peers with HSRP, the upstream is connected to active/standby firewall with OSPF configured.
below is the configuration;
SW1 & SW2
router ospf 1
bfd
router-id 10.10.10.4
area 0.0.0.4 nssa no-summary
interface Vlan20
ip ospf dead-interval 3
ip ospf hello-interval 1
ip ospf network point-to-point
ip router ospf 1 area 0.0.0.4
ip ospf bfd
interface Vlan20
hsrp 20
ip 20.20.20.1
vpc domain 10
peer-switch
role priority 100
peer-keepalive destination 10.10.10.2 source 10.10.10.1 vrf vpcvrf
peer-gateway
layer3 peer-router
auto-recovery
ip arp synchronize
interface port-channel1
vpc peer-link
Switch one neighbor is flapping between EXSTART and EXCHANG
Neighbor ID Pri State Up Time Address Interface
10.10.10.5 1 FULL/ - 00:25:17 20.20.20.3 Vlan20
10.20.10.10 1 EXCHANGE/ - 0.065025 20.20.20.6 Vlan20
Please advice if the above configuration is correct.
12-13-2019 03:06 PM
To understand the problem better, can you post the HLD and how interface connected and full config of both the switches ?
12-14-2019 10:21 PM
Here's the HLD
Here's the configuration;
SW 1
vpc domain 10
peer-switch
peer-gateway
layer3 peer-router
interface Vlan1
no ip redirects
no ipv6 redirects
interface Vlan172
no shutdown
no ip redirects
ip address 172.16.8.5/29
no ipv6 redirects
ip ospf dead-interval 40
ip router ospf 1 area 0.0.0.0
switchport mode trunk
spanning-tree port type network
vpc peer-link
interface port-channel10
switchport trunk allowed vlan 172
vpc 10
interface Ethernet1/1
no switchport
vrf member vpcvrf
ip address 10.10.10.1/30
no shutdown
interface Ethernet1/2
channel-group 1 mode active
interface Ethernet1/3
interface Ethernet1/4
channel-group 10
router ospf 1
router-id 10.10.10.1
SW2
vpc domain 10
peer-switch
peer-keepalive destination 10.10.10.1 source 10.10.10.2 vrf vpcvrf
peer-gateway
layer3 peer-router
interface Vlan1
no ip redirects
no ipv6 redirects
interface Vlan172
no shutdown
no ip redirects
ip address 172.16.8.4/29
no ipv6 redirects
vpc peer-link
vpc 10
no switchport
vrf member vpcvrf
ip address 10.10.10.2/30
no shutdown
channel-group 10
router ospf 1
router-id 10.10.10.2
Here's the output of show ip ospf neighbor
10.10.10.1 1 FULL/DR 08:49:38 172.16.8.5 Vlan172
10.20.10.10 1 EXSTART/DROTHER 00:00:01 172.16.8.1 Vlan172
I have deleted the HSRP configuration for testing but same results.
12-21-2019 01:11 AM
Duplicate post - here
