Community Helping Community
175
Highlighted
Beginner
vPC between nexus 93180 and ASR1002
I have a vPC between a 93180 and an ASR1002 that im not sure is configured correctly. From the nexus switches I see that the port-channel members are in the I (individual) state and show lacp counter shows no received PDUs. It seems to be functional, but shouldn't i see lacp PDUs? Does "spanning-tree bpduguard enable" block lacp PDUs as well?
My nexus port channel configurations:
interface port-channel4
switchport
switchport mode trunk
spanning-tree port type edge trunk
no lacp suspend-individual
vpc 4
interface Ethernet1/3
switchport
channel-group 4 mode active
no shutdown
My ASR1002 port channel configuration:
interface Port-channel4
no ip address
end
interface TenGigabitEthernet0/1/2
no ip address
cdp enable
channel-group 4
Not shown here, but I have a sub interface on the port channel on the AS1002 side with an IP on it. I can ping across and BGP comes up with another device.
2 REPLIES 2
VIP Advisor
Re: vPC between nexus 93180 and ASR1002
we need to have both the side config to look along with show etherchannel summary, show port-chann summary from nexus
or try
channel-group 4 mode on - both the sides.
BB
*** Rate All Helpful Responses ***
VIP Advisor
Hello
have you enabled lacp in the Nxos?
Also on the asr I can see no dot1q or switchport interfaces so the PC won’t establish as a trunk
kind regards
Paul
Please rate and mark posts accordingly if you have found any of the information provided useful.
It will hopefully assist others with similar issues in the future
Content for Community-Ad
FusionCharts will render here
