Highlighted
Beginner
vpc configuration
I need to create a vpc and I would like to ask if I need to configure vlans both on the port-channel interface and the physical interfaces too.
Thank you in advance.
John.
1 ACCEPTED SOLUTION
Highlighted
Rising star
Re: vpc configuration
Hi John,
The question is a bit vague, but assuming that your question is if you need to configure vlans on both port-channel interface and port-channel members (the physical interfaces part of the port-channel), then the answer is no.
And this rule applies on both regular and vPC port-channels. (Almost) Any configuration you are doing on port-channel it will be reflected on PO members.
If this is not what you were looking for, please provide more details and I will try to answer.
Sergiu
2 REPLIES 2
Highlighted
Rising star
Hi John,
Sergiu
Highlighted
Beginner
Hi Sergiu,
My apologies if I wasn't clear but nevertheless you have understood and answered my question appropriately.
Thank you so much.
John
