vpc in Vxlan fabric connectivity issue
Hi all
In VXLAN BGP Evpn fabric which it's leafs are vpc configured...when we upgrade one of the switches and it reboots the traffic to the servers are fine and there is no problem , at the moment of re-enabling downlinks on the upgraded switch, we lose connectivity to server about 12 seconds and after that it will be ok.
i tuned the timers like delay-restore and nve hold-down time in vpc to let every thing converged then enabling downlinks.
actually my question is there is no way to make this connectivity issues from 12 seconds to 0? any ideas?
here is the timers that i changed
vpc delay restore 180s
nve hold-down 210s
5 Replies 5
So you have vPC Nexus as leaf
You upgrade one and then upgrade other and you face this issue?
MHM
I was busy last days
I will check and reply to you tomorrow (hop so)
Thanks for waiting
MHM
Thank you for your time it looks like a bug in vpc delay restore
https://bst.cisco.com/quickview/bug/CSCvm43179
You might consider trying the workaround script provided below:
https://developer.cisco.com/codeexchange/github/repo/blcoffee/vpc_fast_convergence/
