ā11-22-2019 06:13 AM
when i enabled layer 3 peer router command on nexus 5672UP's in VPC, i can see the below message in syslog. I am planning to use VPC peer link for L3 routing (routing adjacency). i will have SVI's configured on this for user segments and will be connected to Core swicthes. I will be running OSPF between this Nexus VPC peers and core switches. Is the command " ayer 3 peer router" applicable for N5K? if so why is it required?
%VPC-2-VPC_ADD_L3_BKUP_VLAN_TO_PEER_GW_EXCLUDE_LIST: Exclude L3 backup routing VLAN from vpc peer-gateway config.
Sridhar
ā11-24-2019 03:20 PM - edited ā11-24-2019 03:23 PM
Hello
Remove the L3 routing VLAN from within the VDC domain regards the specified vpc peer-gateway configuration:
ā12-03-2019 01:40 AM
Hi Paul,
I am not using any VDC. want to establish ospf adjacency between VPC peers via peer link. so want to check if layer 3 peer-router command is applicable here. also plz advise if i need t create separate L3 link between vpc peers for routing adjacency.
ā01-13-2020 11:49 PM - edited ā01-13-2020 11:50 PM
Hello Shri,
Layer 3 peer router command is required when you want to enable to routing over vPC ans this applies to all the Platform.
About the error log,
Remove the routed vlan from vpc peer link to a separated layer 2 trunk fixe this kind problem.Also log message will appear in a mixed chassis setup.
Please rate if this is healpful
Shivakumar
