09-13-2018 08:01 AM
So I have 2 3k access switches in a vPC domain and 2 9k Cores in a vPC domain.
All uplinks between all switches are in vPC channel-group 10
On one 3k switch, all uplinks are int htStdbyIn. The other 3k in that pair is all normal up/up.
On both 9k cores, I have 1 port connecting to each 3k in a suspended state and I can't get up.
Any ideas?
09-13-2018 08:22 AM
That could be cause by many reasons, could you share some more output so we can bettere check what's going on?
On each switch collect the following:
- show port-channel summary interface port-channel 10
- show run int po10
- show lacp interface ethernet $EthernetPort$
- show int $EthernetPort$ | head lines 5
- show run int $EthernetPort$
Alessandro
09-13-2018 09:01 AM
09-13-2018 09:24 AM
Yes that will work, just make sure that you are using a different vpc domain on the couples.
Here some links:
https://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf (look for Double sided VPC)
If you still experience problems share those outputs.
ADP
09-13-2018 10:52 AM
09-18-2018 10:17 AM
Sorry given it was not working I had to change it back to a non-vpc port channel.
So basically, all config regarding port-channels/links between the VPC pairs were all the same except no "vpc 1" command under interface port-channel 1 (not 10 as that was typo".
Here is the output from the commands you mentioned:
On the Core Switch:
interface port-channel1
description Po1_AccSw1
switchport
switchport mode trunk
switchport trunk native vlan 9
mtu 9216
sh port-channel summary interface port-channel 1
Flags: D - Down P - Up in port-channel (members)
I - Individual H - Hot-standby (LACP only)
s - Suspended r - Module-removed
b - BFD Session Wait
S - Switched R - Routed
U - Up (port-channel)
p - Up in delay-lacp mode (member)
M - Not in use. Min-links not met
Group Port- Type Protocol Member Ports
Channel
1 Po1(SU) Eth LACP Eth1/35(P) Eth2/33(P)
sh lacp interface ethe1/35
Interface Ethernet1/35 is up
Channel group is 1 port channel is Po1
PDUs sent: 29502
PDUs rcvd: 29513
Markers sent: 0
Markers rcvd: 0
Marker response sent: 0
Marker response rcvd: 0
Unknown packets rcvd: 0
Illegal packets rcvd: 0
Lag Id: [ [(8000, 0-de-fb-f3-9d-47, 8000, 8000, 1d1), (8000, 4c-77-6d-b1-2d-7f,
8000, 8000, 189)] ]
Operational as aggregated link since Tue Sep 18 16:42:46 2018
Local Port: Eth1/35 MAC Address= 4c-77-6d-b1-2d-7f
System Identifier=0x8000, Port Identifier=0x8000,0x189
Operational key=32768
LACP_Activity=passive
LACP_Timeout=Long Timeout (30s)
Synchronization=IN_SYNC
Collecting=true
Distributing=true
Partner information refresh timeout=Long Timeout (90s)
Actor Admin State=60
Actor Oper State=60
Neighbor: 0x1d1
MAC Address= 0-de-fb-f3-9d-47
System Identifier=0x8000, Port Identifier=0x8000,0x1d1
LACP_Activity=active
Collecting=true
Distributing=true
Partner Admin State=61
Partner Oper State=61
Aggregate or Individual(True=1)= 1
BB1_vPC1_CrSwA_9504_A2B_RU26-32# sh lacp interface ethe2/33
Interface Ethernet2/33 is up
PDUs sent: 22859
PDUs rcvd: 22871
Markers sent: 0
Markers rcvd: 0
Lag Id: [ [(8000, 0-de-fb-f3-9d-47, 8000, 8000, 1d5), (8000, 4c-77-6d-b1-2d-7f,
8000, 8000, 281)] ]
Operational as aggregated link since Tue Sep 18 16:42:45 2018
Local Port: Eth2/33 MAC Address= 4c-77-6d-b1-2d-7f
System Identifier=0x8000, Port Identifier=0x8000,0x281
Collecting=true
Distributing=true
Actor Oper State=60
Neighbor: 0x1d5
System Identifier=0x8000, Port Identifier=0x8000,0x1d5
Collecting=true
Distributing=true
interface Ethernet1/35
switchport
mtu 9216
channel-group 1 mode passive
no shutdown
sh running-config interface et2/33
!Command: show running-config interface Ethernet2/33
version 7.0(3)I7(2)
switchport
mtu 9216
no shutdown
On Access Switch side:
description Po1_CrSw
switchport
mtu 9216
sh por
port-channel port-profile
Channel
1 Po1(SU) Eth LACP Eth1/53(P) Eth1/54(P)
sh lacp int
interface internal
sh lacp interface ethernet 1/53
Interface Ethernet1/53 is up
PDUs sent: 31288
PDUs rcvd: 31554
Markers sent: 0
Markers rcvd: 0
8000, 8000, 189)] ]
Local Port: Eth1/53 MAC Address= 0-de-fb-f3-9d-47
Collecting=true
Distributing=true
Actor Admin State=61
Actor Oper State=61
Neighbor: 0x189
Collecting=true
Distributing=true
Partner Admin State=60
Partner Oper State=60
BB1_vPC2_AccSw1A_93180_A2C_RU38# sh lacp interface ethernet 1/54
Interface Ethernet1/54 is up
PDUs sent: 22873
PDUs rcvd: 22855
Markers sent: 0
Markers rcvd: 0
8000, 8000, 281)] ]
Local Port: Eth1/54 MAC Address= 0-de-fb-f3-9d-47
Collecting=true
Distributing=true
Actor Oper State=61
Neighbor: 0x281
Collecting=true
Distributing=true
show running-config interface Ethernet1/53-54
!Time: Tue Sep 18 17:03:08 2018
version 7.0(3)I7(2)
switchport
spanning-tree port type network
mtu 9216
channel-group 1 mode active
no shutdown
interface Ethernet1/54
switchport
mtu 9216
no shutdown
09-18-2018 01:50 PM
Sorry but if you removed the vpc from the port-channel those commands are not helping anymore. The reason is that VPC will help the 2 peers negotiate some values in order to fool the other side device to believe that there is only one device. Reading the values with VPC enabled will give us the full picture.
ADP
09-19-2018 07:26 AM
