03-27-2019 01:46 AM
We are running a pair of N7K in NX-OS mode. These two switches are connected in a vPC peer set up.
And N3K#1 uplinked to both N7K switches and it's spanning tree root for all VLANs. (it means non-vPC member port)
In this scenario the N3K switch is root bridge and RSTP alternate port will be set on vPC peer-link.
But I found out the rule on vPC will never be blocked on both vPC peer-link.
I wonder how it work with this scenario? No STP blocked port any switch?
03-27-2019 10:10 AM
This scenario is fairly common and you should not have anything to worry about. Nexus in a vPC domain use vPC's Data-Plane Loop Avoidance by default instead of relying on STP/control-plane.
I'd read over vPC Best Practices Guide, Page 8 goes over the Loop Avoidance rule that covers the scenario you're mentioning where all STP ports are Forwarding, link below:
Let me know if something isn't clear. Happy to help.
03-27-2019 05:03 PM
I checked loop avoidance behavior with vPC member ports. But in my case the N3K is not configured port-channel and both N9K switches are not configured vPC member. Just working as legacy RSTP.
In my opinion, N3K is root bridge and both N9K switches peer-link can't be root port, therefore the peer-link will be blocked.
But vPC will never be blocked on both vPC peer-link and it's working as root port.
03-28-2019 02:15 AM
The peer-switch statement under VPC domain configuration will make the N7Ks being seen as a single STP device. That must be configured on both N7K and with the same STP priority on both.
That being said, I don't see any benefit in your STP design instead of aggregating the N3K uplinks into a VPC, which would remove STP questions and allow all uplinks usage. Alternatively, you may think about moving STP Root to N7K if your design permits it.
Remi Astruc
