VSG L3 Connection
Jackie.Wong
Hi:
I have vsg installed and vnmc connected.  Everything seems to fine from the vnmc prespective.  However when I do show vservice brief on the vsm, it shows State: Unreachable.  Any idea how to troubleshoot this?  I have the data 0 defined in the vsg and port-profile defined for the data on vsm.
pr-vsm-01-infradev# sh vservice brief
                                   License Information
Type      In-Use-Lic-Count  UnLicensed-Mod
vsg                      0  3,4,
asa                      0
                                   Node Information
ID Name                     Type   IP-Address      Mode   State   Module
  1 pr-vsg-01-infradev       vsg    10.117.106.189  l3     Unreach 3,4,
                                   Path Information
                                   Port Information
PortProfile:db
Org:root/FT/FT_VDC01
Node:pr-vsg-01-infradev(10.117.106.189)       Profile(Id):prod_profile(1)
Veth Mod VM-Name                              vNIC IP-Address
  25   3 ftorc999-lvpr-uk-t                      1 10.117.209.203
PortProfile:web
  54   4 ftweb999-lvpr-uk-t                      1 10.117.209.202
skalje
Hi Jackie
   Can you ping VSG data interface ip (10.117.106.189) from module 3 and 4 console. VSG state is unreach when VSG is not reachable from the host/module.
Also can you please copy show license usage information on VSM.
Hi Sonali:
I have another setup in another location which is having the same problem.
L3 Unreachable. Here is the output:
osb-vsm-01(config)# sh vservice detail
