I have a connection issue between my VSM (on Nexus 1010) and my VEM. I don't see the VEM witch the show module command.
Control VLAN correctly arrives on the UCS hosting the ESX with VEM.
The control VLAN is different from the ESX Management VLAN. At this time, I used the SVS L2 mode.
Should I use L3 mode ? Or it can work in defining the control VLAN on the ESX (for instance : create a VM in this VLAN or create a vmk interface which belongs to te control VLAN). Cisco documentation is not clear about Control trafic arriving to the ESX and when using L3 mode.
Hugo
