VSUM and N1Kv for vSphere 6.0.0 Issue
alex_aasen
Hi all,
I just got a hold of the newest version of VSUM 1.5.5 to our vSphere 6.0.0 environment. This all seemed great until I tried adding a physical host to the DVS. The issue experienced is the following:
vSphere Web Client Home menue --> Cisco Virtual Switch Update Manager --> Nexus1000v --> Configure --> "Choose DC" --> "Choose DVS" --> Manage --> Add host --> "Try and add a host". And when I try accessing either choice, the "An internal error has happened". So the physical hosts cannot be joined to the N1Kv DVS from here.
Trying another approach to add hosts by "right clicking" the N1Kv SW under the Networking Tab gets me a bit further.
Network Tab --> Right click N1Kv DVS --> Add and Manage Hosts... --> Add host --> "Select host" --> Manage physical adapters --> Assign Uplink and choose the manually generated Ethernet Uplink group made in the VSM --> OK --> Then the error message "The number of physical network adapters per host exceeds the number of uplink ports" appears
Which does not make sense as the uplink port created has a upper limit of like 512 uplink ports.
The port profile has a very basic profile:
port-profile type ethernet UPLINK
switchport mode trunk
switchport trunk allowed vlan all
no sh
system enable
vmware port-group
system vlan 100
I tried installing different N1KV versions, but with no luck, got the same outcome.
According to the VSUM documentation this should have been really straight forward.
Any idea on what might have gone wrong?
32 Replies 32
rmxyz
We are experiencing this issue too. Brand new build of vCenter 6.0u1 (using vCSA), ESXi 6, and Cisco 1000v 5.2(1)SV3(1.5b). Standard VMware distributed switch works perfectly. No solution thus far.
faridsyusifov
Hello. The same issue. Do you find solution?
Here is config:
port-profile type ethernet UPLINKS
  switchport trunk allowed vlan 38,45,86,111-113,886
  no shutdown
  system vlan 38,45,111-113
  state enabled
  vmware port-group
Error message when adding physical network adapters: "the number of physical network adapters per host exceeds the number of uplink ports"
Output of "vem status -v"
Package vssnet-esxesx2015-release
Version 5.2.1.3.1.5a.0-6.0.1
Build 1
Date Sat Aug 15 07:59:51 PDT 2015
VEM modules are loaded
DVS Name         Num Ports   Used Ports  Configured Ports  MTU     Uplinks
Distrib-SW1      1792        9           512               1500    vmnic0
VEM Agent (vemdpa) is running
Tried to add using software client. Success. But I cannot see my VEM module in "sh module" output, plus no network connectivity for VMs.
Here is output after using software client:
Build 1
N1K-PRI          1024        12          1024              1500
Distrib-SW1      1792        7           512               1500    vmnic0
sh modules:
Mod  Ports  Module-Type                       Model               Status
1    0      Virtual Supervisor Module         Nexus1000V          active *
2    0      Virtual Supervisor Module         Nexus1000V          ha-standby
Mod  Sw                  Hw
1    5.2(1)SV3(1.5a)     0.0
2    5.2(1)SV3(1.5a)     0.0
Mod  Server-IP        Server-UUID                           Server-Name
1    192.168.38.18    NA                                    NA
2    192.168.38.18    NA                                    NA
* this terminal session
[Posting on behalf of colleague John Hibbs]:
We need the logs from the N1K Manager (VSUM) to further diagnose.
1. SSH into Nexus 1000v manager. Default username is root and password is cisco.
2. Once logged in, go to /etc/cisco/app_install/ and run ‘./bundleLogs.sh’
Copy off the generated log bundle using scp and attach to this thread.
Robert
Hi Robert,
I work with Robin Malik, who mentioned we are experiencing the same issue as describe in the original post.
I have generated the logs and attached.
Niraj
Niraj,
Does your 1000v contain any PVLAN config by chance?
Robert
Hi Robert,
No private VLAN config, we don't use them in our environment.
Niraj
Found an error in your Ajax logs:
com.cisco.n1kv.exception.PortProfileCreationTimeOut
at com.cisco.n1kv.migrate.MigrateHelper.waitForPortProfileCreation(MigrateHelper.java:1871)
at com.cisco.n1kv.migrate.MigrateHelper.migrateHosts(MigrateHelper.java:1757)
This typically points to a mis-match between the config on the N1K and VC.  Can you provide the following outputs:
  1. ‘Show port-profile’  command output from VSM
  2. Need a screenshot from vCenter > Home > Inventory > Networking > Select VSM(N1kv) > Networks.
Robert
Hi Robert,
Output from show port-profile
cisco-nexus-1000v-poc# show port-profile
port-profile system-uplink
type: Ethernet
description: system-uplink
status: enabled
max-ports: 512
min-ports: 1
inherit:
config attributes:
  switchport trunk native vlan 1034
  switchport trunk allowed vlan 1031-1034,1099,1708
  channel-group auto mode on mac-pinning
  no shutdown
evaluated config attributes:
  no shutdown
assigned interfaces:
  port-channel1
port-group: system-uplink
system vlans: 1031-1033
capability l3control: no
capability iscsi-multipath: no
capability vxlan: no
capability l3-vservice: no
port-profile role: none
port-binding: static
port-profile Unused_Or_Quarantine_Uplink
type: Ethernet
description: Port-group created for Nexus 1000V internal usage. Do not use.
status: enabled
max-ports: 512
min-ports: 1
inherit:
config attributes:
  shutdown
port-group: Unused_Or_Quarantine_Uplink
system vlans: none
port-profile Unused_Or_Quarantine_Veth
type: Vethernet
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  shutdown
port-group: Unused_Or_Quarantine_Veth
system vlans: none
port-profile vc03-poc-exchange
type: Vethernet
description:
status: enabled
max-ports: 16
min-ports: 1
inherit:
config attributes:
  switchport mode access
  switchport access vlan 1099
  no shutdown
  no shutdown
port-group: POC-Exchange
system vlans: 1099
port-profile vc03-poc-server-1
type: Vethernet
description: POC-Server-1
status: enabled
max-ports: 128
min-ports: 1
inherit:
config attributes:
  switchport access vlan 1034
  no shutdown
  no shutdown
port-group: POC-Servers-1
system vlans: 1034
port-profile vc03-poc-server-2
type: Vethernet
description:
status: enabled
max-ports: 256
min-ports: 1
inherit:
config attributes:
  switchport access vlan 1708
  no shutdown
  no shutdown
port-group: POC-Servers-2
system vlans: 1708
port-profile vc03-poc-storage
type: Vethernet
description: Development storage
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 1033
  no shutdown
  no shutdown
port-group: POC-Storage
system vlans: 1033
port-profile vc03-poc-vMotion
type: Vethernet
description: Development vMotion
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 1032
  no shutdown
  no shutdown
port-group: POC-vMotion
system vlans: 1032
port-profile vc03-poc-vmsc
type: Vethernet
description: Development ESXi Management
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 1031
  no shutdown
  no shutdown
port-group: POC-VMSC
system vlans: 1031
capability l3control: yes
  1. Need a screenshot from vCenter > Home > Inventory > Networking > Select VSM(N1kv) > Networks.
I cannot find this path within vSphere, I have uploaded a couple of screenshots in the hope they hold the information you require. We are using vSphere 6 web interface if that helps.
Hello, Robert.
Here is output:
sh port-profile
port-profile COMMON-86
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 86
  no shutdown
  no shutdown
port-group: COMMON-86
system vlans: none
port-profile CONTROL
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 111
  no shutdown
  no shutdown
port-group: CONTROL
system vlans: 111
port-profile MNGMT
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 38
  no shutdown
  no shutdown
port-group: MNGMT
system vlans: 38
port-profile PACKET
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 112
  no shutdown
  no shutdown
port-group: PACKET
system vlans: 112
port-profile SECURE-886
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 886
  no shutdown
  no shutdown
port-group: SECURE-886
system vlans: none
type: Ethernet
status: enabled
max-ports: 512
min-ports: 1
inherit:
config attributes:
  shutdown
system vlans: none
type: Vethernet
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  shutdown
system vlans: none
port-profile UPLINKS
type: Ethernet
description:
status: enabled
max-ports: 512
min-ports: 1
inherit:
config attributes:
  no shutdown
  no shutdown
port-group: UPLINKS
system vlans: 38,45,111-113
port-profile vMotion
type: Vethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
  switchport access vlan 45
  no shutdown
  no shutdown
port-group: vMotion
system vlans: none
And one more thing. It is succesful, when you adding vmnic using software client. But no network connectivity. VMs are cut out from outside network. And againg no VEM module in sh modules output.
Thanks.
I'm not sure if this apparent UI bug is the Cisco plugin or something to do with VMware. Either way, I was able to circumvent the vSphere Web Client error using PowerCLI.
The code is below. It assumes the following:
  1. Your host is imported to vCenter.
  2. Your host has have 2 physical NICs.
  3. vmnic0 is being used by the standard vSwitch for current management traffic.
  4. You have VUM installed (if you do not, you'll need the VEM installed).
  5. You are using PowerCLI 6.0 Release 2 build 3056836 (older versions may work).
This script will:
  1. Add the host to the 1000v with vmnic1, which invokes VUM to install the VEM (if you have the VEM already installed the addition to the 1000v will be much quicker).
  2. Migrate the management network from vSwitch on vmnic0, to 1000v with vmnic1
  3. Remove vmnic0 from vSwitch
  4. Add vmnic0 to 1000v (must be done by "adding" both vmnic0 and 1, even though vmnic1 is already added).
Hope this helps someone.
Please don't start pasting errors with this code into this thread. If you want, create a new thread and link to it.
$verbosepreference = 'continue'
$DebugPreference = 'continue'
$vcenterServer = 'myvcenter'
$esxihost = 'myhost.domain.com'
$shush = Connect-VIServer -Server $vcenterServer -Credential (Get-Credential) -Protocol Https -ErrorAction Stop -WarningAction SilentlyContinue
$esxiHostObj = Get-VMHost -Name $esxihost -ErrorAction Stop
# Define your 1000v name:
$ciscoVDSName = 'my1000v'
$ciscoVDSObj = Get-VDSwitch $ciscoVDSName
# Specify the 1000v uplink
$uplinkPortGroupName = 'system-uplink'
# Define management port group (port profile)
$vmkpg = 'POC-VMSC'
# Add vmnic1 to 1000v with system-uplink:
$vmnic = 'vmnic1'
$vmHost = Get-VMHost -Name $esxihost -Erroraction Stop | Get-View
$spec = New-Object -TypeName VMware.Vim.DVSConfigSpec
$targetHost = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberConfigSpec
$targetHost.operation = 'add'
$targetHost.backing = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicBacking
$pnic = $vmHost.Config.Network.Pnic | Where-Object -FilterScript {
    $_.Device -eq $vmnic
$targetHost.Backing.PnicSpec = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec
$targetHost.Backing.PnicSpec[0].pnicDevice = $pnic.Device
$uplinkObj = Get-VDPortgroup -Name $uplinkPortGroupName
$targetHost.Backing.PnicSpec[0].UplinkPortGroupKey = $uplinkObj.Key
$targetHost.host = $vmHost.MoRef
$spec.Host = $targetHost
$dvSwitch = Get-View -Id $ciscoVDSObj.ExtensionData.MoRef
$dvSwitch.UpdateViewData()
$spec.ConfigVersion = $dvSwitch.Config.ConfigVersion
$taskMoRef = $dvSwitch.ReconfigureDvs_Task($spec)
$taskID = 'Task-' + $taskMoRef.Value
while((Get-Task -Id $taskID).PercentComplete -lt "100")
    $percentComplete = (Get-Task -Id $taskID).PercentComplete
    Write-Verbose "Percent Complete: $percentComplete"
    Start-Sleep -Seconds 3
# Move vmk management network to 1000v on vmnic1
$vNicManagement = Get-VMHostNetworkAdapter -VMHost $esxihost -Name vmk0
$vdPortgroupManagement = Get-VDPortgroup -VDSwitch $ciscoVDSName -Name $vmkpg
$pnicToUse = Get-VMHostNetworkAdapter -VMHost $esxihost -Physical | Where-Object { $_.Name -eq $vmnic }
Add-VDSwitchPhysicalNetworkAdapter -DistributedSwitch $ciscoVDSName -VMHostPhysicalNic $pnicToUse -VMHostVirtualNic $vNicManagement -VirtualNicPortGroup $vdPortGroupManagement -ErrorAction Stop -Confirm:$false
# Remove vmnic0 from vswitch
$esxihostobj | Get-VMHostNetworkAdapter -Physical -Name "vmnic0" | Remove-VirtualSwitchPhysicalNetworkAdapter -Confirm:$false
# add vmnic0 to 1000v
$config = New-Object -TypeName VMware.Vim.HostNetworkConfig
$config.proxySwitch = New-Object -TypeName VMware.Vim.HostProxySwitchConfig[] -ArgumentList (1)
$config.proxySwitch[0] = New-Object -TypeName VMware.Vim.HostProxySwitchConfig
$config.proxySwitch[0].changeOperation = 'edit'
$config.proxySwitch[0].uuid = $ciscoVDSObj.key
$config.proxySwitch[0].spec = New-Object -TypeName VMware.Vim.HostProxySwitchSpec
$config.proxySwitch[0].spec.backing = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicBacking
$config.proxySwitch[0].spec.backing.pnicSpec = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec[] -ArgumentList (2)
$config.proxySwitch[0].spec.backing.pnicSpec[0] = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec
$config.proxySwitch[0].spec.backing.pnicSpec[0].pnicDevice = 'vmnic0'
$config.proxySwitch[0].spec.backing.pnicSpec[0].uplinkPortgroupKey = $uplinkObj.key
$config.proxySwitch[0].spec.backing.pnicSpec[1] = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec
$config.proxySwitch[0].spec.backing.pnicSpec[1].pnicDevice = 'vmnic1'
$config.proxySwitch[0].spec.backing.pnicSpec[1].uplinkPortgroupKey = $uplinkObj.key
$vmhostRef = ($vmhost.MoRef.value).split('-')[1]
$_this = Get-View -Id "HostNetworkSystem-networkSystem-$vmhostRef"
$_this.UpdateNetworkConfig($config, 'modify')
Hello, Robin
Thank you very much for your post. I tried to add vmnics to N1K switch using PowerCLI, but unsuccessful.
I am facing the issue in the thread and another stubborn one related to it. Cannot add the host to the NX1000v VDS - be it by WebClient, vSphere client or PowerCLI. Funny enough I am getting exactly same error when adding the host via PowerCLI or adding it via the vSphere "thick" client. And the error info points to an internal ESXi host SOAP call failure.
I am using latest and greatest vSphere 6.0.0.update02-3620759 patched with latest and greatest ESXi600-201611001.zip from VmWare, vSphere client downloaded from the patched ESXi host, Using Nexus1000v.5.2.1.SV3.2.8 and latest & greatest vCenter Server Appliance VMware-VCSA-all-6.0.0-3634788. I am starting "clean" each test i.e. in NX1000v I am doing in "svc connection <test-svc-conn>" "no vmware dvs datacenter-name <test-dc> ; no connect" then I recreate the dvs clean-slate.
Here is the error
vDS operation failed on host 192.168.198.98, Received SOAP response fault from [<cs p:00007f1425ae9990, TCP:192.168.198.98:443>]: invokeHostTransactionCall
Received SOAP response fault from [<cs p:1f37cb58, TCP:localhost:8307>]: invokeHostTransactionCall
An error occurred during host configuration. got (vim.fault.PlatformConfigFault) exception
I recall when I have upgraded from 5.1 to 5.5 upgraded using the latest & greatest 5.5 vmVisor image from vMware - and had the exact same issue with Nexus 1000v. Finally after many hours of shooting in the dark I have downgraded the 5.5. vmVisor a notch and the error disappeared. I am for now in the dark with this error and what is causing it.
Thanks in advance for any suggestion
p.s. the script I believe needs some adjustments - I have modified it a bit ( I am just doing "add" and for 2 vnics) but regardless some initializations might be required e..g. in my slightly modified version
###$targetHost.Backing.PnicSpec = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec
$targetHost.Backing.PnicSpec = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec[] (2)
$targetHost.Backing.PnicSpec[0] = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec
$targetHost.Backing.PnicSpec[1] = New-Object -TypeName VMware.Vim.DistributedVirtualSwitchHostMemberPnicSpec
Did more testing and here is what I have found. The root cause of the issue seems to be the fact I have done an "upgrade" from 5.5 to 6.0 - it is not the vmVisor version. Dit a fresh install of 6.0 U2 (w/ preserve datastore) and LOL adding the host worked just fine (from the "thick" vSphere client). Now I recall that during the 5.1 => 5.5 upgrade I have also initially done an "upgrade". Then I have reverted to the 5.5. GA "standard" version but did a full install (w/ preserve datastore). Lesson learned - stay away from the  vmVisor "upgrade" function - always do a fresh install to upgrade. At least one issue solved - unfortunately still not able to add the host from the web client getting same nonsensical error "The number of physical network adapters per host exceeds the number of uplink ports"
Hello. But I do not have N1K Manager (VSUM) installed in my production.
