VXLAN and Nexus 1000V L3 Control Mode
trerober
Hello All,
Has anyone had any issues getting VXLAN to work with the Nexus 1000V in L3 Control Mode?
I followed the L3 Control instructions found here: http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9902/guide_c07-556626.html#wp9000165
I included the step to use the control0 interface on the VSM for VEM communication.
However, the VMs on my bridge domain could not communicate.  When I did show ip mroute on the L3 Switch, the VXLAN Multicast Group showed up briefly and would then disappear.  Also, the hosts where my VMs were running did not show up as members of the IGMP Group.
When I switched back to  L2 Control mode, suddenly, VXLAN communications began working between the VMs.
I used the same procedure to setup VXLAN communications that I posted on my blog: http://vmtrooper.com/vxlan-on-ucs-and-vsphere-from-l3-to-nexus-1000v/
I'm not sure why L3 Control Mode presented a problem.  I may have missed something when configuring the VSM for L3 Control Mode, but I did verify that the VSM was able to see the ESXi hosts properly when I added them (i.e. they showed up properly with the show module command).  Also, my test VMs communicated just fine on a standard VLAN.
I plan on trying this config again when I have test servers available.  Unfortunately, I could not continue troubleshooting since this environment was due for another project.
Any insights would be appreciated!
-Trevor
Your config looks good.
That comment about the additional uplinks from the deployment guide is news to me.
I always just created one big port-channel and made VXLAN part of that PC.
I'll see if I can get clarification on it.
There is a great slide deck on VXLAN on Ciscolive365 that was done by Larry Kreeger. I'd highly recommend taking a look at it. VXLAN will try to do the right thing when it comes to MTU. It will try to do path discovery. When it comes to multicast in a lot of cases VXLAN looks like it's working but the switch is really just flooding.
louis
lwatta
Trevor,
I would need a little more info to really troubleshoot the issue. Do you still have the running config from the N1Kv?
Also I looked at your blog and I see you set the MTU on the NIC but did you change the MTU in the QOS settings for the best effort network class? Also looking at your environment if all your VXLAN capable ESXi hosts are just in the UCS system and the vmk interfaces are in the same subnet you should be able to just get by with igmp querier enabled on the UCS.
On the ESXi side were you using the same VMK for both l3 control and vxlan? We recommend VMK interfaces for VXLAN be used just for VXLAN.
The good news is that the next version of N1KV will have a version of VXLAN that does not require multicast :-)
louis
Hello louis,
Thanks for responding, and sorry to be so vague.  I will not be able to replicate the environment any time soon since I had to get VXLAN working for the team project.  As such, I don't know if the show run will be useful, but I will include it below anyway.
I totally neglected updating the Best Effort Network Class.  It was still set to "normal"  Since I was able to get the setup working before, I didn't think to check that item.  It is now at 1600 MTU to match what I set on the vNICs.
I saw that the UCS can now be the IGMP querier (I think that capability may not have been availalbe when I wrote the article).  That is something I'd like try in version 2.0 of my VXLAN Setup post (if the VXLAN functionality update doesn't arrive first!).
I am using separate vmkernels for VXLAN and L3 Control, and they are on different subnets.  One thing I noticed in the 1000V Deployment Guide this morning:
"This scenario requires an additional vmkernel interface with an IP address, and a separate uplink (VMNIC) interface on the VMware ESXi host for the Layer 3 (VSM-to-VEM) interface."
In that case, I'll need to assign additional vNICs to the Service Profile and create a separate Ethernet Uplink Port-Profile just for L3 Control when using the control0 interface?  I missed this step during my setup last night, and I will try this out during Round 2 of my VXLAN-L3 Control Setup.
Yes, I heard about the VXLAN update at EMC World.  I'm looking forward to no longer depending on multicast!
Trevor
--show run---
!Command: show running-config
!Time: Thu May 30 14:53:53 2013
version 4.2(1)SV2(1.1a)
svs switch edition essential
no feature telnet
feature segmentation
feature network-segmentation-manager
ssh key rsa 2048
ip domain-lookup
ip host sspN1kv 172.16.94.2
hostname sspN1kv
errdisable recovery cause failed-port-state
vem 3
  host vmware id 00000000-0000-0020-0000-000000000006
vem 4
  host vmware id 00000000-0000-0020-0000-000000000005
vem 5
  host vmware id 00000000-0000-0020-0000-000000000003
vem 6
  host vmware id 00000000-0000-0020-0000-000000000004
bridge-domain vxtest
  segment id 5001
  group 239.1.1.1
vrf context management
  ip route 0.0.0.0/0 172.16.94.1
vlan 1,140,144,155-156,161-162
vlan 140
  name Vblock_VXLAN
vlan 144
  name Vblock_VM_Mgmt
vlan 155
  name Vblock_ESXi_Mgmt
vlan 156
  name Vblock_ESXi_vMotion
vlan 161
  name Vblock_N1K_Pkt-Ctrl
vlan 162
  name Vblock_N1K_L3_Control
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type vethernet NSM_template_vlan
  no shutdown
  description NSM default port-profile for VLAN networks. Do not delete.
  state enabled
port-profile type vethernet NSM_template_segmentation
  no shutdown
  description NSM default port-profile for VXLAN networks. Do not delete.
  state enabled
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type ethernet Uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 140,144,155-156,161-162,180
  mtu 1600
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 140,144,155-156,161-162
  state enabled
port-profile type vethernet VXLAN
  vmware port-group
  switchport mode access
  switchport access vlan 140
  capability vxlan
  no shutdown
  system vlan 140
  state enabled
port-profile type vethernet tenant-vxlan
  vmware port-group
  switchport access bridge-domain vxtest
  no shutdown
  state enabled
port-profile type vethernet ControlPacket
  vmware port-group
  switchport access vlan 161
  no shutdown
  system vlan 161
  state enabled
port-profile type vethernet SSP_Infrastructure_Management
  vmware port-group
  switchport access vlan 144
  no shutdown
  system vlan 144
  state enabled
port-profile type vethernet ESXi_Management
  vmware port-group
  switchport access vlan 155
  no shutdown
  system vlan 155
  state enabled
port-profile type vethernet ESXi_vMotion
  vmware port-group
  switchport access vlan 156
  no shutdown
  system vlan 156
  state enabled
vdc sspN1kv id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 1 maximum 1
  limit-resource u6route-mem minimum 1 maximum 1
interface port-channel1
  inherit port-profile Uplink
  vem 5
interface port-channel2
  vem 3
interface port-channel3
  vem 4
interface port-channel4
  vem 6
interface mgmt0
  ip address 172.16.94.2/24
interface Vethernet1
  inherit port-profile ESXi_Management
  description VMware VMkernel, vmk0
  vmware dvport 320 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0025.B52A.0000
interface Vethernet2
  inherit port-profile ESXi_vMotion
  description VMware VMkernel, vmk2
  vmware dvport 352 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.5664.7715
interface Vethernet3
  inherit port-profile VXLAN
  description VMware VMkernel, vmk3
  vmware dvport 64 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.566A.1D28
interface Vethernet4
  vmware dvport 321 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0025.B52A.0001
interface Vethernet5
  vmware dvport 353 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.566E.3D73
interface Vethernet6
  vmware dvport 65 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.5669.95E6
interface Vethernet7
  inherit port-profile tenant-vxlan
  description Test 2, Network Adapter 1
  vmware dvport 385 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.56AB.5E9E
interface Vethernet10
  description Test 1, Network Adapter 1
  vmware dvport 386 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.56AB.1999
interface Vethernet12
  vmware dvport 322 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0025.B52A.0004
interface Vethernet13
  vmware dvport 354 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.5663.7674
interface Vethernet14
  vmware dvport 67 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.5661.51CE
interface Vethernet16
  vmware dvport 323 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0025.B52A.0003
interface Vethernet17
  vmware dvport 66 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.5668.CA20
interface Vethernet18
  vmware dvport 355 dvswitch uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64"
  vmware vm mac 0050.5665.6567
interface Ethernet3/1
interface Ethernet3/2
interface Ethernet4/1
interface Ethernet4/2
interface Ethernet5/1
interface Ethernet5/2
interface Ethernet6/1
interface Ethernet6/2
interface control0
  ip address 172.16.72.2/24
line console
boot kickstart bootflash:/nexus-1000v-kickstart.4.2.1.SV2.1.1a.bin sup-1
boot system bootflash:/nexus-1000v.4.2.1.SV2.1.1a.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart.4.2.1.SV2.1.1a.bin sup-2
boot system bootflash:/nexus-1000v.4.2.1.SV2.1.1a.bin sup-2
ip route 0.0.0.0/0 172.16.72.1
ip route 0.0.0.0/0 172.16.73.1
svs-domain
  domain id 559
  control vlan 161
  packet vlan 161
  svs mode L2
svs connection vCenter
  protocol vmware-vim
  remote ip address 172.16.94.5 port 80
  vmware dvs uuid "63 33 2b 50 f8 79 3f 8d-a0 5d 9e f0 1e b6 63 64" datacenter-name SSP
  max-ports 8192
  connect
vservice global type vsg
  tcp state-checks invalid-ack
  tcp state-checks seq-past-window
  no tcp state-checks window-variation
  no bypass asa-traffic
vnm-policy-agent
  registration-ip 0.0.0.0
  shared-secret **********
  log-level
network-segment manager switch
  mgmt-server-uuid "2A9A0407-09F1-4DB6-9457-114DC3945C41"
  dvs name sspN1kv
network-segment policy default_vlan_template
  description Default template used for VLAN backed pools
  type vlan
  import port-profile NSM_template_vlan
network-segment policy default_segmentation_template
  description Default template used for isolation backed pools
  type segmentation
  import port-profile NSM_template_segmentation
louis
Thanks lous!
will check it out.  That separate vmnic advice in the guide seemed to be specific to when the control0 interface is used explicitly for the VEM communication.  I didn't see it mentioned elsewhere.
Either way, it would be good to know definitively.
-Trevor
