VXLAN BGP VNE - VNI STATE NONE
Max Castillo
Hi, i have an issue with the vxlan bgp vne, for some reason i'm unable to make the state UP for the VNI.
So, i'm unable to ping to the remote host for the same vlan.
For some reason i have the mac address of the remote host, but isn't storage in the ARP Table.
Leaf-01# show mac address-table dynamic vlan 300
Legend:
        * - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC
        age - seconds since last seen,+ - primary entry using vPC Peer-Link,
        (T) - True, (F) - False, C - ControlPlane MAC, ~ - vsan
   VLAN     MAC Address      Type      age     Secure NTFY Ports
*  300     aabb.cc00.0600   dynamic  0         F      F    Eth1/5
C  300     aabb.cc00.0d00   dynamic  0         F      F    nve1(172.29.100.131)
Leaf-01# show ip arp vlan 300 vrf produccion
Flags: * - Adjacencies learnt on non-active FHRP router
       + - Adjacencies synced via CFSoE
       # - Adjacencies Throttled for Glean
       CP - Added via L2RIB, Control plane Adjacencies
       PS - Added via L2RIB, Peer Sync
       RO - Re-Originated Peer Sync Entry
       D - Static Adjacencies attached to down interface
IP ARP Table
Total number of entries: 1
Address         Age       MAC Address     Interface       Flags
10.2.0.100      00:08:28  aabb.cc00.0600  Vlan300
Leaf-01#
Leaf-01# show nve internal platform interface nve 1
Printing Interface ifindex 0x49000001
|Intf  |State                    |PriIP          |SecIP          |
|nve1  |UP                       |172.28.100.129 |172.28.100.131 |
Leaf-01# show nve internal platform interface nve 1 detail
Printing Interface ifindex 0x49000001 detail
SW_BD/VNIs of interface nve1:
|Sw BD |Vni   |State                    |Intf  |Type|Vrf-ID|Notified
|300   |1000300|NONE                     |nve1  |CP  |0     |No
|900   |1000900|NONE                     |nve1  |CP  |4     |No
Peers of interface nve1:
no peers
Leaf-01# show nve peers
Interface Peer-IP State LearnType Uptime Router-Mac
nve1 172.29.100.131 Up CP 01:13:10 0200.ac1d.6483
Leaf-01# show running-config nv overlay
!Command: show running-config nv overlay
!Running configuration last done at: Tue Feb  2 16:37:55 2021
!Time: Tue Feb  2 16:59:41 2021
version 9.3(5) Bios:version
feature nv overlay
vlan 300,304,308,500,900-902,1012-1014
interface nve1
  no shutdown
  host-reachability protocol bgp
  advertise virtual-rmac
  source-interface loopback1
  member vni 1000300 mcast-group 225.0.1.44
  member vni 1000900 associate-vrf
Leaf-01#
The topology that i'm doing is attached.
In one site have Spine and leaf topology, and the other side it's like a leaf-spine collapsed.
Hope someone can give me a hand.-
Thank you !.
Max Castillo
Ok, didn't notice that the command advertise l2vpn evpn was deprecated, i remove vrf from BGP, and now it's working.
I just can't understand why the state still in none...anyways, now i have conectivity between hosts from the same vlan and the outside.
vinugenie
Could you share the following logs:
- show run vlan 300
- show run vlan 900
- show run interface vlan 300
- show run interface vlan 900
- show nve vni
I would also look at the below :
no peers
It should show NVE peers.
Question: Are your other VTEPs advertising same VNI's.
Once I look at the configuration, I will be able to respond in a better way. At this point, more information is needed.
--Vinit
Hi, i changed a little bit the topology, becasue i lost the topology. Anyways, i'm having the same result about the nve peers.
For some reason i see no peers in the platform, but i able to ping between servers in the same vlan. Also, i have installed the BGP to l2rib, and the tunnel ID are correct.
I attached the topology, and the commands that you request.
Leaf-1# show running-config vlan 200
vlan 200
vlan 200
  name Produccion
  vn-segment 100200
Leaf-1# show running-config vlan 900
vlan 900
vlan 900
  name Produccion-L3
  vn-segment 100900
Leaf-1# show running-config interface vlan 200
interface Vlan200
  no shutdown
  vrf member produccion
  ip address 10.150.14.254/24
  ip ospf passive-interface
  fabric forwarding mode anycast-gateway
Leaf-1# show running-config interface vlan 900
interface Vlan900
  description # Produccion L3 #
  no shutdown
  ip forward
Leaf-1# show nve vni
Codes: CP - Control Plane        DP - Data Plane
       UC - Unconfigured         SA - Suppress ARP
       SU - Suppress Unknown Unicast
       Xconn - Crossconnect
       MS-IR - Multisite Ingress Replication
Interface VNI      Multicast-group   State Mode Type [BD/VRF]      Flags
nve1      100200   225.0.0.2         Up    CP   L2 [200]
nve1      100300   225.0.0.1         Up    CP   L2 [300]
nve1      100900   n/a               Up    CP   L3 [produccion]
nve1      100901   n/a               Up    CP   L3 [qa]
Leaf-1# show mac address-table dynamic vlan 200
Legend:
C  200     aabb.cc00.0c00   dynamic  0         F      F    nve1(192.168.100.2)
*  200     aabb.cc00.0e00   dynamic  0         F      F    Eth1/
Leaf-2# show system internal l2fm debugs | i aabb.cc00.0e00
2021 Feb 16 14:58:09.793627: E_DEBUG    l2fm [4583]: l2fm_l2rib_mac_update(23765): Ignored remote mac aabb.cc00.0e00
2021 Feb 16 14:58:09.793623: E_DEBUG    l2fm [4583]: l2fm_handle_generic_l2_entry(14123): Ignoring entry if_index 0x49080001, vl 200 mac aabb.cc00.0e00 state 3
2021 Feb 16 14:58:09.793517: E_DEBUG    l2fm [4583]: l2fm_macdb_insert(9268): unexpected! entry aabb.cc00.0e00 already exists in SW. skip HW install
2021 Feb 16 14:58:09.793449: E_DEBUG    l2fm [4583]: l2fm_macdb_insert(8929): temp_str = slot 32 fe 0 mac aabb.cc00.0e00 vlan 200 flags 0x7 hints 0 E8 NL lc  : if_index 0x49080001 old_if_index 0
2021 Feb 16 14:58:09.793434: E_DEBUG    l2fm [4583]: l2fm_rvtep_intf_update_mac_nl_move(1277): UFDM find entry by ip for mac aabb.cc00.0e00,peer_id=1,peer_ip=192.168.100.1
2021 Feb 16 14:58:09.790318: E_DEBUG    l2fm [4583]: l2fm_mcec_rmdb_delete(222): Deleting MAC aabb.cc00.0e00 vlan 200 from RMDB
2021 Feb 16 14:58:09.790296: E_DEBUG    l2fm [4583]: l2fm_l2rib_mac_update(23757): Add L2RIB remote mac aabb.cc00.0e00, flags 0x7
2021 Feb 16 14:58:09.790292: E_DEBUG    l2fm [4583]: l2fm_l2rib_mac_update(23743): VLAN:200 Add L2RIB remote mac aabb.cc00.0e00, ifindex 0x49080001
2021 Feb 16 14:58:09.789475: E_DEBUG    l2fm [4583]: l2fm_process_l2rib_remote_route_update(633): Type: 2 Len: 180 Seq: 0, del: 0 (Prod: 5) Flags: Ctrl=3 Rt=0, mac aabb.cc00.0e00 topo_id 200, esi_valid FALSE
2021 Feb 16 14:58:09.784260: E_DEBUG    l2fm [4583]: l2fm_macdb_insert(8929): temp_str = slot 32 fe 0 mac aabb.cc00.0e00 vlan 200 flags 0x7 hints 0 E8 NL lc  : if_index 0x49080001 old_if_index 0
2021 Feb 16 14:58:09.784053: E_DEBUG    l2fm [4583]: l2fm_rvtep_intf_update_mac_nl_move(1198): UFDM reported rvtep for mac aabb.cc00.0e00,peer_id=1,peer_ip=192.168.100.1
2021 Feb 16 14:58:09.783569: E_DEBUG    l2fm [4583]: l2fm_mcec_rmdb_delete(222): Deleting MAC aabb.cc00.0e00 vlan 200 from RMDB
2021 Feb 16 14:58:09.783500: E_DEBUG    l2fm [4583]: l2fm_l2rib_mac_update(23757): Add L2RIB remote mac aabb.cc00.0e00, flags 0x7
2021 Feb 16 14:58:09.783496: E_DEBUG    l2fm [4583]: l2fm_l2rib_mac_update(23743): VLAN:200 Add L2RIB remote mac aabb.cc00.0e00, ifindex 0x49080001
2021 Feb 16 14:58:09.748110: E_DEBUG    l2fm [4583]: l2fm_process_l2rib_remote_route_update(633): Type: 2 Len: 180 Seq: 0, del: 0 (Prod: 5) Flags: Ctrl=3 Rt=0, mac aabb.cc00.0e00 topo_id 200, esi_valid FALSE
Leaf-2# show ip route vrf produccion
IP Route Table for VRF "produccion"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
10.150.14.0/24, ubest/mbest: 1/0, attached
    *via 10.150.14.254, Vlan200, [0/0], 00:50:36, direct
10.150.14.100/32, ubest/mbest: 1/0
    *via 192.168.100.1%default, [200/0], 00:48:09, bgp-65000, internal, tag 65000, segid: 100900 tunnelid: 0xc0a86401 encap: VXLAN
10.150.14.101/32, ubest/mbest: 1/0, attached
    *via 10.150.14.101, Vlan200, [190/0], 00:46:46, hmm
10.150.14.254/32, ubest/mbest: 1/0, attached
    *via 10.150.14.254, Vlan200, [0/0], 00:50:36, local
Leaf-2# show nve internal bgp rnh database
Total peer-vni msgs recvd from bgp: 2
Peer add requests: 2
Peer update requests: 0
Peer delete requests: 0
Peer add/update requests: 2
Peer add ignored (peer exists): 0
Peer update ignored (invalid opc): 0
Peer delete ignored (invalid opc): 0
Peer add/update ignored (malloc error): 0
Peer add/update ignored (vni not cp): 0
Peer delete ignored (vni not cp): 0
Showing BGP RNH Database, size : 2 vni 0
Flag codes: 0 - ISSU Done/ISSU N/A        1 - ADD_ISSU_PENDING
            2 - DEL_ISSU_PENDING          3 - UPD_ISSU_PENDING
VNI       Peer-IP            Peer-MAC            Tunnel-ID  Encap     (A /S ) Flags PT    Egress VNI
100200    192.168.100.1      0000.0000.0000      0x0        vxlan     (1 /0 ) 0     FAB   100200
100900    192.168.100.1      5004.0000.1b08      0xc0a86401 vxlan     (1 /0 ) 0     FAB   100900
Leaf-2# show nve internal platform interface nve 1 detail
|nve1  |UP                       |192.168.100.2  |0.0.0.0        |
|200   |100200|NONE                     |nve1  |CP  |0     |No
|300   |100300|NONE                     |nve1  |CP  |0     |No
|900   |100900|NONE                     |nve1  |CP  |3     |No
|901   |100901|NONE                     |nve1  |CP  |4     |No
no peers
