10-08-2019 07:57 AM
Does anyone know how can we configure Vlan 1 on VXLAN EVPN? We're using DCNM to deploy a fabric.
We can create any vlans ffrom 2-3967. We tried to configure manually:
leaf01-F(config)# vlan 1
leaf01-F(config-vlan)# vn-segment 30001
Message reported by command :: end
Can't configure vnsegment id for Native Vlan 1
Cannot run commands in the mode at this moment. Please try again.
ERROR: Failed to write VSH commands
It doesn't seem to allow it, but we need it!!
Appreciate any help.
02-13-2020 04:04 AM
I have the same problem too, will that able to fixed by native vlan setting?
any solution you found?
02-13-2020 05:15 AM
Hi Perkin.
The solution was to upgrade the code of the switches.
I guess our switches were Nexus 93108tc-ex and Nexus 93180yc-ex running version 9.2(2) and we upgraded to 9.2(3). After that, we could configure vlan 1 with its corresponding vnid, just as other vlans.
However DCNM doesn't allow to configure vlan 1 from "Networks" tab, so we had to configure Vlan 1 from the Leaf Freeform Config tab on Fabric Builder option.
configure profile vlan1
vlan 1
vn-segment 30001
interface Vlan1
vrf member VRF-name
no ip redirects
no ipv6 redirects
fabric forwarding mode anycast-gateway
no shutdown
02-13-2020 05:49 AM
