VxLAN Slow Performance when routing
LewisD1
I have encountered a strange issue which i'm hoping someone can help me figure out.
We have Cisco Nexus 9K switches deployed with VXLAN and MP-BGP EVPN. We have a few VRFs configured on the switches as such we have a few L3VNIs.
When we are routing traffic between networks using the Anycast Gateways on the cisco Nexus we are getting terrible performance.
For these iPerf Tests i have deployed iPerf into the guestshell but the issues are there even when not running in the guestshell
iPerf from Host to Host using just L2 - Gbits/Sec
Client connecting to 10.255.3.12, TCP port 5001
TCP window size: 3.84 MByte (default)
[ 3] local 10.255.3.11 port 38534 connected with 10.255.3.12 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 28.5 GBytes 24.5 Gbits/sec
iPerf from Host to Switch SVI - Kbits/sec
Client connecting to 10.255.3.1, TCP port 5001
TCP window size: 390 KByte (default)
[ 3] local 10.255.3.11 port 42228 connected with 10.255.3.1 port 5001
[ 3] 0.0-11.2 sec 896 KBytes 654 Kbits/sec
iPerf Test from Switch SVI to Host - Mbits/Sec
Client connecting to 10.255.3.11, TCP port 5001
TCP window size: 520 KByte (default)
[ 3] local 10.255.3.1 port 18524 connected with 10.255.3.11 port 5001
[ 3] 0.0-10.0 sec 116 MBytes 97.2 Mbits/sec
iPerf from Host to Host via L3
I did this test but dont have a grab of it but again around 300Kbit/Sec
Can anyone point me in the right direction of where to look.
Hanfeng Cai
Basically, switch is doing HW forwarding, I don't believe you hit such basic performance issue. You can take a look the physical path of your testing flow and figure out which hop triggers this problem. In case of any low speed issue, I always suspect packets are punt to switch's CPU.
Forgot to update the ticket. The issue was IP redirects which was hitting the CPU like you said. Once I enabled no IP redirects the issue went away.
That's cool.
