10-30-2018 01:21 PM - edited 10-30-2018 01:23 PM
For Nexus 3132Q-V switches, if I wanted to check logs or something happened before, where or how can I do that? Thanks!
10-31-2018 08:12 AM
Did you configure a syslog server. If the switch has not rebooted and there was enough buffer you can always check the 'show log' output to see the logging messages
10-31-2018 08:45 AM
Thanks! two follow-ups:
Does that mean logs would not be persistent after reboot the switch?
How do I set up syslog? I don't see it in docs.
10-31-2018 02:03 PM
